Spotlight Wiring
Posted: Fri Aug 15, 2025 4:56 pm
by CatGuy
I'm going to mount a spotlight to the windshield of my '26. Where is the best place place to connect the wire?
Re: Spotlight Wiring
Posted: Fri Aug 15, 2025 5:35 pm
by Humblej
You could run a wire to the tail light connection on the firewall terminal block and it will only work when the lights are on, or to the battery connection on the terminal block if you want it to work all the time.
Posted: Fri Aug 15, 2025 6:03 pm
Did you drive the T to your new home yet. Is the spotlight required now :P
Posted: Fri Aug 15, 2025 7:02 pm
by jsaylor
It would be best to include an on-off switch if it doesn't already have one. Mine had a twist switch built into the connector on the rear of the light.
Posted: Mon Aug 18, 2025 8:34 am
by CatGuy
Not yet. That's on the 29th. The longest drive for the T in many years and the longest I've ever driven one!
Posted: Mon Aug 18, 2025 12:01 pm
I would wire it from the battery lead, (the thick yellow wire), with a switch placed in-line. That way, it can be used at any time, whether or not the car is running or if the headlights lights are turned on.
