Ford decal for side of speedster gas tank.
Posted: Mon Aug 18, 2025 1:52 pm
by Meestro
I recently finished the build of a 1926 Model T Speedster with an oval gas tank. I would like to add the appropriate Ford decal for the period on the sides of the gas tank but cannot seem to find a place to purchase them, even though I have seen many gas tanks with the decal/vinyl on the side. Any idea where to purchase them decals?
[image][/image]
Re: Ford decal for side of speedster gas tank.
Posted: Mon Aug 18, 2025 2:54 pm
by RajoRacer
Ebay has a bunch !
Posted: Mon Aug 18, 2025 4:03 pm
by Meestro
Thanks, I will give it a try again.
Posted: Mon Aug 18, 2025 6:39 pm
by Ed Fuller
Any local vinyl graphics shop or sign shop should be able to print up one for a reasonable price if you can’t find what you are looking for.
Posted: Mon Aug 18, 2025 8:00 pm
by Allan
If you are using a standard T oval tank, most I have seen have a depressed X pattern in the ends. A vinyl stick-on may not be the answer. A vehicle wrap type application should do the trick. Maybe neither will appreciate fuel being spilled over them.
Allan from down under
