Low radiator shell
Posted: Tue Jul 02, 2019 5:36 am
by Cambin
Hi there
I’m in Australia and trying to find a good low Nickle radiator shell
I have a good painted one but is not correct for this model
Any info or Leeds would be much appreciated
Cheers
Cam
Re: Low radiator shell
Posted: Tue Jul 02, 2019 8:51 am
by Mark Osterman
I didn’t know Ford offered a plated shell in the low radiator era.
Posted: Tue Jul 02, 2019 9:27 am
That nickel low shell was an import dealer option in NZ, and likely AU too.
Older post showing details of nickel plated low shells in 1920 parts list of NZ Ford distributor. That option of nickel wasn't in the USA for low radiator shell, unless the owner or local dealer did that plating on special basis. Not really a USA occurrence.
http://www.mtfca.com/discus/messages/50 ... 1219110898
Posted: Tue Jul 02, 2019 11:32 am
by Erik Johnson
Why not plate the shell that you have in your possession?
Posted: Tue Jul 02, 2019 4:30 pm
by Cambin
Looking at the quality of today isn’t like the old days and the costs
And finding a decent plater
Posted: Wed Jul 03, 2019 9:32 am
Cam, if you can find a none too rusty shell to plate, we have an excellent plater here in South Australia. When I had the one done for my D &F roadster, I was allowed to fix the dents, soft solder fill the rust pits and do the initial polishing, to reduce costs. However, when the young fellow did the final polishing, he got it a bit hot and that meant my soft solder on the top of the panels was taken out a bit and the pits show somewhat.
I have since found a much better shell and had that plated by a different crew and the results are excellent. This was a steel shell. They had already done a 26-7 brass one for a customer and that was excellent, so I knew they did good work. Mt new one cost $660 to plate, so finding a good shell and plating it could run to $1000. My brother-in-law is paying for my plating job. He gets my other one for his car at no cost. His was a cut down high shell made to fit a low radiator when his car should have a high radiator, so we are both winners.
Posted: Tue Jul 09, 2019 8:29 am
by Cambin
Well Allen if I don’t do any good I will find out of you your plater
Cam
