grant oil ring install.
Posted: Fri Aug 22, 2025 4:52 pm
by bobt
Hello. I'm TRYING to install the grant oil ring on my .030 over aluminum piston I ordered .40 over rings because the old ring gap was too wide. Everything was going fine till I came to the two piece oil ring. The instructions do not say how and the people at grants are gone for the day. My problem is , How do you adjust the inner coil spring that's inside the oil ring? NOBODY had HASTINGS rings
Re: grant oil ring install.
Posted: Fri Aug 22, 2025 6:22 pm
by bobt
I'm guessing that I should grind a bit off of the spring? It does come apart. bobt
Posted: Fri Aug 22, 2025 6:26 pm
by Jack Putnam, in Ohio
"Inner coil spring", it's a coil spring. It will compress. I see no reason to "adjust" it.
Posted: Fri Aug 22, 2025 6:52 pm
Just install it - like Jack stated - it's a spring & it will compress just fine - I've installed many & never "adjusted" that piece !
Posted: Fri Aug 22, 2025 7:06 pm
by Dan McEachern
as above,the expander will be ok but check the end gap on both rails. Did you also check the gap on the top two rings? Top two need about .018 gap. About .012 on the oil minimum.
Posted: Fri Aug 22, 2025 7:40 pm
by Dan Hatch
Bob: Don’t let the word out that someone from Va installed GRANT rings in his car. You could be tarred and feathered, then run out of town on a rail.
Posted: Sat Aug 23, 2025 5:52 am
by bobt
Thanks Dan. I never thought of that. Like Dylan said " The times they are a'changin". Thank's for all the replies. I'll be installing my DAMN YANKEE rings this afternoon. bobt
Posted: Sun Aug 24, 2025 8:51 pm
by Craig Leach
Hi Robert,
I assume you found a older set of Grant 2 piece oil rings with the flat springs? As stated above be careful to not get the gap to small! If you have
a acceptable gap on the ring the spring should be OK but if you have to grind the gap one would think that you would remove the same from
the spring. If you found a set with the 2 piece oil ring congrats as the new ring sets come with the 3 piece oil rings. They probably work just as
good but I find them some what of a pain to compress. Having spent most of my hobby engine building on air cooled motorcycle engines I prefer
to error on the larger ring gap for safeties sake and have not found it to be a problem with water cooled engines that turn under 3,000 rpm.
Craig.
Posted: Tue Sep 02, 2025 5:57 am
by bobt
Just a follow up---I tried shortening the spring on the Grant two piece oil ring but it still was binding. I found a set of Hastings rings with a one piece oil ring. Set the gaps to .017 and installed them, It started on the third crank! thanks for all the input. bobt
