Help with this mess
Mountainrider
First Name: Neil
Last Name: Haywood
Help with this mess
Post by Mountainrider » Tue Jul 02, 2019 8:16 pm
Climb under the T this afternoon to tighten a nut holding the muffler to the frame that had come loose and was rattling. Found this mess. is this normal?
Bill Robinson
First Name: Bill
Last Name: Robinson
MTFCA Number: 22487
MTFCI Number: 17887
Re: Help with this mess
Post by Bill Robinson » Tue Jul 02, 2019 8:22 pm
Actually, it's better than normal. :roll:
Last Name: Gregush
Post by Mark Gregush » Tue Jul 02, 2019 8:27 pm
I have seen worse. There is no seal in that area so when grease gets mixed with oil from the output shaft and warm, it just kinda finds it way out. You would too if you were being slung around at speed.
1921 Huckster
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Jul 02, 2019 9:01 pm
Looks like your solution is the same as mine. Cardboard!
Dan B
Last Name: Blaydon
Post by Dan B » Tue Jul 02, 2019 9:24 pm
I would only be worried if you didn’t see any grease in that area.
Post by Norman Kling » Tue Jul 02, 2019 9:32 pm
That's good! You are getting enough grease to the joint. If you don't like the way it looks wipe it off. You will need to wipe often though. I always put a drip pan under the rear part of the engine and transmission to catch some of the oil and grease.
I don't know about the gaskets in your ball joint but some people put two. One between the ball joint and the hogs head and another between the ball joint and the cover. You should only have one gasket. The one between the hogs head and the ball joint. If you use the second one, it will push your cover too far back causing more oil and grease to leak out.
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Tue Jul 02, 2019 9:41 pm
Thanks everyone. Feeling better about it. The rest of the motor seem pretty drip free.
JP_noonan
Last Name: Noonan
Post by JP_noonan » Tue Jul 02, 2019 9:48 pm
Neil, one thing you should definitely do is safety wire those two lower bolts on the U-joint ball cap. ;)
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Jul 03, 2019 10:21 am
All normal T's do that!
MTFCA Number: 1219
Post by Rich Eagle » Wed Jul 03, 2019 10:47 am
Thanks for reminding me what it looks like. I try not to look at mine. Sometimes engine oil mixes in with the grease. A friend has a theory that Henry designed it so the engine oil would find it's way down the torque tube and lubricate the differential. Amusing but if it weren't for the grease the oil would likely come out around the ball joint.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Wed Jul 03, 2019 2:30 pm
Your T is rustproofing its undercarriage.
1924 Touring
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Jul 04, 2019 10:41 am
I hope that isn't graphite grease I'm looking at!
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Thu Jul 04, 2019 12:15 pm
No it isn’t.
26troadster
Last Name: Lloid
Board Member Since: 2014
Post by 26troadster » Thu Jul 04, 2019 6:47 pm
My 26 rpu does it and I wipe it off when I change the oil. No problems yet.
