Help with this mess
Posted: Tue Jul 02, 2019 8:16 pm
by Mountainrider
Climb under the T this afternoon to tighten a nut holding the muffler to the frame that had come loose and was rattling. Found this mess. is this normal?
Re: Help with this mess
Posted: Tue Jul 02, 2019 8:22 pm
by Bill Robinson
Actually, it's better than normal. :roll:
Posted: Tue Jul 02, 2019 8:27 pm
by Mark Gregush
I have seen worse. There is no seal in that area so when grease gets mixed with oil from the output shaft and warm, it just kinda finds it way out. You would too if you were being slung around at speed.
Posted: Tue Jul 02, 2019 9:01 pm
by Dallas Landers
Looks like your solution is the same as mine. Cardboard!
Posted: Tue Jul 02, 2019 9:24 pm
by Dan B
I would only be worried if you didn’t see any grease in that area.
Posted: Tue Jul 02, 2019 9:32 pm
by Norman Kling
That's good! You are getting enough grease to the joint. If you don't like the way it looks wipe it off. You will need to wipe often though. I always put a drip pan under the rear part of the engine and transmission to catch some of the oil and grease.
I don't know about the gaskets in your ball joint but some people put two. One between the ball joint and the hogs head and another between the ball joint and the cover. You should only have one gasket. The one between the hogs head and the ball joint. If you use the second one, it will push your cover too far back causing more oil and grease to leak out.
Posted: Tue Jul 02, 2019 9:41 pm
by Mountainrider
Thanks everyone. Feeling better about it. The rest of the motor seem pretty drip free.
Posted: Tue Jul 02, 2019 9:48 pm
by JP_noonan
Neil, one thing you should definitely do is safety wire those two lower bolts on the U-joint ball cap. ;)
Posted: Wed Jul 03, 2019 10:21 am
by Original Smith
All normal T's do that!
Posted: Wed Jul 03, 2019 10:47 am
by Rich Eagle
Thanks for reminding me what it looks like. I try not to look at mine. Sometimes engine oil mixes in with the grease. A friend has a theory that Henry designed it so the engine oil would find it's way down the torque tube and lubricate the differential. Amusing but if it weren't for the grease the oil would likely come out around the ball joint.
Posted: Wed Jul 03, 2019 2:30 pm
by RustyFords
Your T is rustproofing its undercarriage.
Posted: Thu Jul 04, 2019 10:41 am
by Original Smith
I hope that isn't graphite grease I'm looking at!
Posted: Thu Jul 04, 2019 12:15 pm
by Mountainrider
No it isn’t.
Posted: Thu Jul 04, 2019 6:47 pm
by 26TRoadster
My 26 rpu does it and I wipe it off when I change the oil. No problems yet.
