Presto-lite tank question
John Haynes
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
MTFCA Number: 27737
Post by John Haynes » Tue Jul 02, 2019 11:00 pm
I am restoring a Presto-Lite tank and have some questions and need some help. I have a tank with the raised letters that say "Prest -o-Lite". The tank has a valve on the end that is to one side of the tank. Does this valve go on the bottom, top, left or right side when mounted on the running board? Did all Presto-Lite tanks have a stencil on them? Does the valve end of the tank face the front or the back of the car? I would appreciate any help in this regard! Thank you in advance!
Regards,
John Haynes
babychadwick
First Name: Chad
Last Name: Azevedo
* REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
Re: Presto-lite tank question
Post by babychadwick » Tue Jul 02, 2019 11:39 pm
Valve goes up.
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
MTFCA Number: 5414
Post by BHarper » Tue Jul 02, 2019 11:42 pm
Hi John,
The valve goes at the top.
As to the the valve at the front or at the back, I have see it both ways in period photographs and on restored cars. I suspect that tank orientation was entirely owner preference and convenience. For some, it might have been easier to have the valve at the front and the gauge at the rear of the tank would be protected from flying stones. Good luck with your project, Bill
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jul 02, 2019 11:43 pm
The tank is mounted horizontally with the valve at the top. Generally the valve is at the front (closest to the headlights). All the original tanks I have seen were nickle plated.
Hope this helps.
John Haynes
Last Name: Haynes
MTFCA Number: 27737
Post by John Haynes » Wed Jul 03, 2019 12:31 pm
]Thank you Chad, Bill and Les. I will try to attache a photo of the two Presto-lite tanks I have. One appears to have a galvanized coating and the other appears to be nickel plated. On the nickel plated one, there is remnants of a stencil, there is no such remnants on the galvanized one. Bill, thank you for all of the photos!
Regards,
John[image][/image]
Presto_lite_tanks.zip
Presto-lite tanks
(119.11 KiB) Downloaded 118 times
KeithG
First Name: Keith
Last Name: Gumbinger
MTFCA Number: 4661
MTFCI Number: 6866
Post by KeithG » Wed Jul 03, 2019 1:22 pm
Hi John, I also have 2 P O L tanks & both have the galvanized finish. I have one on my '14 Touring and I painted it with Rustoleum silver. I mounted it with the valve to the front of the car, and of course with the offset valve to the top. I agree with the others that the valve can be to the front or rear of the car, which ever the owner prefers.
I really like the P O L tank and use it mostly at the OCF. The lights remain bright for as long as I want them on, not like the generator where the lights go dim after having them on for awhile.
Keith
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Jul 03, 2019 3:57 pm
John-
Here is my Prest-O-Lite tank:
It is a B type tank.
Restoration Supply has a decal for the "E style" tank, which is shorter than the B.
I got my "B type" decal from a forum member who had some made.
Keith
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Wed Jul 03, 2019 4:17 pm
I bought decal for the "E style" tank on Ebay
Super Mario Bross ;)
1911 Touring
1914 Speedster
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Wed Jul 03, 2019 6:04 pm
John, I finally found the right tank at a welding supply house. Stripped it and painted it silver. Got the repro decal from Restoration Supply. Mine looks a lot like KWs'.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Wed Jul 03, 2019 7:59 pm
While on the topic of tanks, how does one go about getting one certified or filled?
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Wed Jul 03, 2019 9:08 pm
Chad that is a good question.That seems to vary. Where I am no one will fill a tank with a gauge. With the gauge removed and a plug in it's place they will take it for refill but only on exchange which doesn't work because you rarely find a tank where the valve is offset. Years ago there was a guy in NJ who would fill anything you brought him but he died and I am still running on the tanks he filled for me. I believe he filled them from a larger tank. Fortunately, I had 3 extra tanks filled by him but I am down to one tank now and have gone back to using my generators and carbide on my other cars.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Wed Jul 03, 2019 10:01 pm
I have not tried this but it is an idea and when I get to the point of using my tank (yard sale find for $2) I will dwell on my boating experience when it comes to filling oddball propane tanks. Take a full tank and invert it take your empty tank and set below. Run a hose between the two with no regulators and raise the full tank inverted above the empty tank. From what I have heard this may take a day or two and it helps if the lower tank is cooled in say a barrel of ice water.
