We just noticed blackened paint by the rear brake . .
Topic author - Posts: 7
- Last Name: Markel
- * REQUIRED* Type and Year of Model Ts owned: 1909 Toring
- MTFCA Number: 10085
and are wondering if it’s a lack of grease, or something worse . . Any thoughts ?
- First Name: Erik
- Last Name: Johnson
Re: We just noticed blackened paint by the rear brake . .
Your brake shoes are dragging on the drums and the heat from the friction burned the paint.
yup
NH Full Flow Float Valves
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
- MTFCA Number: 11598
James, Fix and adjust the dragging parking brakes not to drag on drums when hand lever is forward. Also read post on how to adjust for a free neutral. When you clean and repaint the drums in the damaged area, keep the repaint to a thin layer, the burnt paint looks way to hick in the picture.
- Last Name: Markel
