Modern LED Bulb Numbers
Posted: Sun Sep 14, 2025 5:58 am
by ModelTWoods
Can anyone post the bulb numbers for LED bulbs used in the Ford dash light and the C.M. Hall made Ford stoplight ? I'm sure they are all single contact, and I think, all straight pin, but different candlepower.
Re: Modern LED Bulb Numbers
Posted: Sun Sep 14, 2025 8:43 am
by Moxie26
Do a search on forum and you'll come up with answer with bulbs others may use.... https://www.logolites.com/ ..,... viewtopic.php?f=2&t=49668.
Posted: Tue Sep 16, 2025 7:52 pm
by Moxie26
Hey Terry, how you doing... Any progress with your LED bulb application?
Posted: Tue Sep 16, 2025 9:29 pm
by ModelTWoods
Robert, I had previously ordered the adjustable LED headlight bulbs from Logo Lights, so I went back to their webssite. They do have an LED small miniature bulb that will work for the dash light and a tail light, but not for a stop light bulb. If need be, I'll just use a regular incandescent bulb for the stop light function.
Posted: Wed Sep 17, 2025 6:19 am
by RVA23T
A second source:
www.ledlight.com
And here is the 6 volt search result link:
https://www.ledlight.com/6-volt-positiv ... ights.aspx
Posted: Wed Sep 17, 2025 7:43 am
by Moxie26
Aware that their stoplight bulb is not available at this time, was the question asked on when they would have replenish stock available?
