Hassler spring install
Posted: Sun Sep 14, 2025 9:31 am
by Wingnut
Hello all, after the rebuild of a friend's rear axle we're having issues putting the springs in place. I wasn't involved in their removal so I didn't see how he got them out. This is on a 1920 touring with, what I'm told, is a California top. He has it on a lift which is a difficult install operation for me, I'm used to working on the floor. We've tried compressing them and wiring them, can almost get it but no cigar. Does anyone with experience in Hassler springs have a recipe method of install. We thank you for your support, Wingnut
Re: Hassler spring install
Posted: Sun Sep 14, 2025 10:22 am
by Erik Johnson
Hasslers came with a dedicated tool to compress the spring. However, you can compress the spring with it in the bracket with a homemade version using a piece of threaded rod, two nuts, a washer and a flat piece of steel with a hole drilled in it as I described here:
https://www.mtfca.com/discus/messages/1 ... 1281825166
And here:
https://www.mtfca.com/discus/messages/4 ... 1398691007
Posted: Sun Sep 14, 2025 12:45 pm
by TRDxB2
Wingnut wrote: ↑Sun Sep 14, 2025 9:31 am
Instructions +
- 731241.jpg (113.51 KiB) Viewed 918 times
- 731242.jpg (97.76 KiB) Viewed 918 times
- 731243.jpg (103.27 KiB) Viewed 918 times
- 731244.jpg (103.22 KiB) Viewed 918 times
Posted: Sun Sep 14, 2025 12:48 pm
by TRDxB2
Posted: Sun Sep 14, 2025 1:44 pm
by Erik Johnson
If you make a tool yourself, it doesn't have to be as complicated/fancy as the Hassler factory issue tool.
As I posted above, a length of all-thread, two nuts, a washer and a flat piece of steel with a hole drilled in it will suffice to compress the spring in the bracket.
Posted: Sun Sep 14, 2025 7:13 pm
by Wingnut
Thanks , we'll give it ago with a home made version. really appreciate it . Wingnut
Posted: Mon Sep 15, 2025 8:34 pm
by TRDxB2
Wingnut wrote: ↑Sun Sep 14, 2025 7:13 pm
As a safety precaution. have some kind of strap around a spring coil & the base its being attached to in case the the tool slips.
Posted: Mon Sep 15, 2025 10:20 pm
by RajoRacer
A good place for heavy nylon tie straps !
Posted: Wed Sep 17, 2025 9:13 am
by Wingnut
Thanks to all the great advice and tips, we made a tool as pictured, and BAM went together like a charm. Wingnut
