Searching the Forum
Posted: Thu Jul 04, 2019 11:13 am
I have been having trouble search the Forum for things I want to read about. If the item of the search is only one word, it works OK. But... if I'm looking for a two word item, the search comes back with each word individually. This generally included a lot of stuff that is not wanted. For example, If I were to search for Rod Bolt, I would get every instance of Rod alone and Bolt alone. In other Forum searches, if you surround the word sin quotes then the two words are joined, but that doesn't seem to work here. It would be nice to see a listing of how to search some where. I looked at the advanced search and there is a little blurb, but it is not helpful. Put a + for word you want and a - for those you don't? Thanks Mike
