What have you done to/with your Model T in September?
Posted: Thu Sep 18, 2025 7:23 am
by varmint
Made a sleeve between the timer and the adjustment rod; used grease. There was that much play. (background is 60 grit)
I had used screws with a plus + in order to attach the rain gutters to the top wood and tried to hide my sins with some black silicone.
- timer sleeve.jpg (20.63 KiB) Viewed 2202 times
- cover sins.jpg (59.2 KiB) Viewed 2202 times
Re: What have you done to/with your Model T in September?
Posted: Thu Sep 18, 2025 8:42 am
by South Park Zephyr
I finally got the chance to install the wood bed kit my wife got me for Christmas , added disk wheel covers (thanks to Herb Iffrig),mad the support arm for my passenger side mirror, and went on the Hillbilly tour.
Posted: Thu Sep 18, 2025 9:05 am
by babychadwick
I managed to finish wrapping the wheel. Believe me it takes a while to get it right.
Posted: Thu Sep 18, 2025 8:59 pm
by haydonr
Got our '12 back from the paintshop... now for upholstery...
Posted: Fri Sep 19, 2025 10:21 am
by KWTownsend
Haydon,
Beautiful looking paint job. Is it black?
Since you are bown under and the car is right hsns drive, I presume the body was made by Wm. Gray & Sons. I'm curious; What is the body number? It will be stamped into the wood on the seat riser in front of the gas tank cover, and on the underside of the fore-door, and one of the back doors.
Keith
Posted: Fri Sep 19, 2025 4:17 pm
by haydonr
Hi Keith,
It's definitely blue in the right light (a slight purple tinge in some lights).
The body is a modern repro that came with the project when we bought it in pieces from a deceased estate. It should technically be a slab side based on the 117,xxx engine number, but this is the body that the previous owner imported for it and we weren't going to throw it away (plus I like this shape).
Haydon
Posted: Fri Sep 19, 2025 9:17 pm
by Jones in Aiken SC
Got the top irons pretty much ready to go to get a top put on my 12 Roadster, along with some pinstriping. Hopefully all done by end of October!
Posted: Fri Sep 19, 2025 9:51 pm
by haydonr
Also just taught my wife to drive the '13 today
Posted: Sat Sep 20, 2025 8:53 am
by Tadpole
Went Pawpaw pickin’, the cat helped
Posted: Sat Sep 20, 2025 9:57 am
by babychadwick
I also started on the garage pouring the slab by hand and dug out some parts that survived multiple hurricanes and moves and set them together to start thinking on the next build.
Replacement (unstamped) '14 block, early cross drive mag, DR4 mag (combination mag and dist), early hoggshead, nims water pump, and a fronty ported and worked over by Sherman.
Posted: Sun Sep 21, 2025 6:25 am
by henryford2
Putting them to bed for the winter and moving them around so the wife can get her car in the garage!
Posted: Sun Sep 21, 2025 8:09 pm
by rwephill
Built a grain bed for the TT.
- EvansTTBed.JPG (48.13 KiB) Viewed 1602 times
Posted: Fri Sep 26, 2025 3:51 am
by Jevil
Had an easy job this month - I just bought one:
Posted: Fri Sep 26, 2025 4:14 am
by varmint
Congrats Jens! It's a beaut'
Posted: Fri Sep 26, 2025 2:22 pm
by Shrshot
Took the Tudor to our family reunion. Was a great ride and a great day.
Posted: Sat Sep 27, 2025 2:08 pm
by varmint
Drove the T to the gas station for the first time in decades and put in $10 of 87 non-ethanol. Serignan's gas station opened in 1927, has stayed in the same family, so it seemed fitting. This is a photo of it from 2017 and is within a mile of the Ford assembly plant.
Posted: Mon Sep 29, 2025 12:47 pm
by CatGuy
I drained the 2 year old fuel and bought a new battery. I'll hopefully do more when I feel up to it.
