replace closed cab with C Cab
Posted: Sun Sep 28, 2025 2:02 pm
by clee2
Is is possible to replace the closed cab of a TT with a C-Cab? Just trying to find out the logistics of it.
Re: replace closed cab with C Cab
Posted: Sun Sep 28, 2025 2:05 pm
by Humblej
Yes you can.
Posted: Sun Sep 28, 2025 5:07 pm
by A Whiteman
Here are the options:
C Cab (well maybe a 'square C :-) ) No Cab (Roadster) and Closed Cab (Colonial), :
Posted: Sun Sep 28, 2025 6:58 pm
by George House
Yes; it’s perfectly interchangeable. The 4 Ford TT cab mounting brackets on the frame are the same for a Ford TT enclosed cab and Ford TT C cab.
Posted: Fri Oct 03, 2025 1:12 pm
by clee2
Thanks for the info
Posted: Fri Oct 03, 2025 2:16 pm
by RajoRacer
O.T. - kinda - George - love your Lang's October calendar photo !
Posted: Fri Oct 03, 2025 2:52 pm
by kmatt2
Because your TT has a 1925-27 closed cab you are good to go and change out the Ford closed cab for a Ford C cab. In 1925 when Ford came out with the closed cab they changed the front cab mounting bracket so that either type cab will mound to the bracket. But if the TT is a 1924 chassis the front cab mounting bracket is smaller and is only designed to mount the C cab.
Posted: Sat Oct 04, 2025 3:18 am
by George House
Awww… thanks for the recognition Steve. But I can’t find my calendar now. :oops:
