Piston and babbit!
Posted: Sun Oct 05, 2025 9:28 pm
by Abakca
Babbit looks new on all except for piston 2. Piston 1 skirt looks like wtf happened here?
Follow the link and let me know what you guys think please!
https://www.facebook.com/share/p/1FSp8Bh1dc/
Re: Piston and babbit!
Posted: Sun Oct 05, 2025 10:25 pm
If I have to go to facebook to see your problem, I'm going to just nope right out of here
MTFCA spends the money to put up and maintain a Forum, an administrator deals with BOTS and goofballs constantly, and you use it to redirect us to the biggest collection of condensed ignorance in the world?
Not a chance
You might actually consider posting pix and info here or risk losing this audience. At the very least it would show some modicum of respect for MTFCA and the posters here.
Posted: Mon Oct 06, 2025 8:35 am
by Art Ebeling
That rod babbit looks similar to what I posted two days ago about a number two rod babbit failure. Art
Posted: Mon Oct 06, 2025 8:58 am
The piston is scored badly. The cause could be improper piston or ring fit, a bent rod, piston pin too tight, or lack of oil. Overheating is another possibility, but given that the #2 rod bearing is completely burned out, I suspect improper fit/installation issues, or someone ran the engine without oil, or someone put heavy oil in a newly rebuilt engine and fired it up on a cold morning and raced it to "break it in right". It looks to me like you will need to do an in-chassis overhaul at the very least. If no reliable history is available, it would probably be best to remove the engine/transmission assembly and ship it to a competent rebuilder, unless you are willing and able and equipped to do the work yourself. The car looks good, from what I can see, but it certainly looks as if engine work was not done correctly, or the engine has been abused in some way, such as severe overheating or run with a lack of oil, or run hard after a rebuild without proper break-in.
Posted: Mon Oct 06, 2025 10:12 am
by Lil Teezy
I’m with Scott on this one, but unfortunately people just don’t think that way anymore. More likely to be considered inappropriate for complaining, or bringing it up than for disrespecting the effort that goes into this site in the first place. $#!tty aspect of today’s world but most folks would wonder what “problem” we’re even talking about… -Grouchy old Chris, in Boulder
Posted: Mon Oct 06, 2025 10:33 am
I also dont do fake book.
Based on Pat's description, I can add recent experience.
I had a T motor come in seized. Primarily from head gasket leaks that rusted & stuck #4 piston.
During the tear down & rebuild I discovered #1 piston & bore severely scored. (original iron pistons)
Fortunately babbit was savable with shim removal & time saver.
As always the why is important.
In this case the inside oil funnel was completely clogged with chunks of carbon & paraffin based oil.
Posted: Mon Oct 06, 2025 11:47 am
Someone may have fit aluminum pistons to the original Ford spec, which is for cast iron pistons and is too tight for aluminum pistons. New pistons in a worn and out of round bore can also cause trouble, as can new pistons fitted in a tapered bore. Model T transmissions have some critical fits, and if the engine guy also worked on the transmission, it probably needs to be assessed.
Posted: Mon Oct 06, 2025 3:54 pm
by Abakca
Here are the photos for the non Facebook folks. Have a great day!
Posted: Mon Oct 06, 2025 5:39 pm
by big2bird
I'm sorry to see that.
It needs to come out and apart.
It boils down to budget and skill level, which includes tools.
On the other hand, stock motors are quite forgiving. I've seen stuff that should not run, run fair.
Posted: Tue Oct 07, 2025 8:35 am
by J and M Machine
The piston being scored along with poor babbitting , Basically engine overheated or parts weren't sized accordingly. Babbitt of the rod wasn't tinned and it is lead based babbitt.
