1926-27 T Pickup Bed Center Pan
Posted: Fri Oct 24, 2025 2:01 pm
by TA Man
I'm looking for anyone who has an original "FLOOR REAR CROSS MEMBER HOUSING" for the 26-27 T Pickup Bed. This is the center pan that is located over the rear crossmember. I'd like to get some profile photos of the pan out of the bed, but in the bed would be ok too. Also, does anyone have the T part number for this piece?
Re: 1926-27 T Pickup Bed Center Pan
Posted: Fri Oct 24, 2025 3:12 pm
by Original Smith
Are you sure it's called a housing? I thought it was a cover?
Posted: Fri Oct 24, 2025 3:20 pm
by Scott_Conger
Dan
good luck...you should get what you're looking for...99% of us know what you're talking about and what you call it makes no difference.
welcome to the affliction!
Posted: Fri Oct 24, 2025 4:03 pm
by DanTreace
T-48815 is part number of the '26-'27 Housing (rear cross member) as noted in the Price List of Body Parts book.
Bed plate0004.jpg (37.49 KiB) Viewed 734 times
Bed plate0002.jpg (33.43 KiB) Viewed 734 times
Bed plate0001.jpg (35.77 KiB) Viewed 734 times
Lang's used to sell that part as Lang's # PBEDAD, but no longer avail, these were made by Howells a few years ago.
Posted: Fri Oct 24, 2025 4:10 pm
by big2bird
You should do your homework.
Posted: Fri Oct 24, 2025 7:20 pm
by Henry K. Lee
uhmmmmmmm Hey Moe Hey Larry.......,,,,,, Ouch..., Ouch...., Stop It!
Posted: Sat Oct 25, 2025 12:08 am
by TA Man
Hey guys, thanks for the info on the pan, the photos are great and part number too.
It's my understanding that the pan is kind of humped up in the middle between the strips, where the Model A pan is all flat across the top. I'm guessing that the rear crossmember needed just a little more clearance under the pan on the T than on the A.
I may see if I can get the drawing for this from the Benson Archives.
Does anyone have a photo of the top profile showing the hump?
Posted: Sat Oct 25, 2025 6:00 am
by varmint
There are three photos in this recent thread of it installed correctly.
https://mtfca.com/phpBB3/viewtopic.php?f=2&t=49974
Posted: Sat Oct 25, 2025 11:56 am
by TA Man
Thankyou for the link to that thread!
