Horn switch advice, '27 Coupe
Posted: Sun Nov 02, 2025 8:30 am
by Mike S
My '27 Coupe has the horn switch on the side of the column with a metal bracket that wraps around the column. There are two tabs on the internal portion of the switch and one of those tabs that holds the internal portion of the switch and secures the entire mechanism has broken, making the switch loose. I've looked for a replacement for the internal switch but cannot seem to find one. Should I replace the entire switch mechanism with a modern one or keep trying to find the internal portion of the switch, or try to solder the tab back on the original? Thanks!
Re: Horn switch advice, '27 Coupe
Posted: Sun Nov 02, 2025 9:17 am
by Humblej
Replace with a better original, they are not hard to find and are not expensive.
Posted: Sun Nov 02, 2025 11:50 am
by jab35
Mike: In my experience that internal horn switch cylinder with contacts and mounting supports all molded together is difficult to find. I don't believe anyone is making that part at the moment. It took me over a year to find a usable original on the Forum classifieds.
That said, I'd suggest placing a part wanted advert, and maybe contact your favorite supplier to see if they might have that part. Best, jb
Posted: Sun Nov 02, 2025 12:17 pm
If you cant find an illusive usable original unit, repair what you have.
I have one with a tab broken away from the bakelite. Easy enough to make a tab & epoxy or hot glue it in place.
You have the other side as a sample.
A tab could be modified from an electric plug prong.
Posted: Sun Nov 02, 2025 1:52 pm
by varmint
I'd like to see a photo of the damage.
Posted: Sun Nov 02, 2025 2:01 pm
by Dan Hatch
Part number 8028x page 178 2015 Langs catalog.
Someone made the whole switch once. Should be some out there somewhere.
Posted: Sun Nov 02, 2025 2:28 pm
I have several I'll need to post them
Posted: Sun Nov 02, 2025 10:16 pm
by Altair
The original horn button came out of the center of the steering wheel.
Posted: Sun Nov 02, 2025 10:21 pm
Posting them now (3 x 1918-1925, 1926-27 and a 1915)
Posted: Tue Nov 04, 2025 11:55 am
Yes, but only on Canadian cars.
