Splash Shields
Posted: Thu Nov 13, 2025 1:36 pm
by Campbell Tellman
Good Afternoon1
I am working on a '16 touring car. Frame off. I cannot find info on the reassembly. When I lifted the body off of the frame I found 1/4 inch rubber pads at the bolt sites. My main question is do the splash shields mount between the body and frame without the rubber pads?
Are the rubber pads on top of the frame or between the body and the splash shields?
Thanks,
Campbell Tellman II
Beaufort, NC
Re: Splash Shields
Posted: Thu Nov 13, 2025 1:40 pm
Neater above or below. There were no pads used on T's. Someone may have added to level the body out so you might want to check the frame rails for sag. If you did want to add them, I would suggest on top of the running board aprons, so the body sits on them.
