What a useful wrench
Topic author - Posts: 384
- First Name: Neal
- Last Name: Willford
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
- MTFCA Number: 50256
I would imagine/hope that every T driver has this wrench in their tool kit in the car. I knew that it was for the spark plugs and nuts for my demountable wheels, but since I've been restoring my 15 runabout I've come to realize how useful it is for other areas of the car. I even used it today to remove the gascolator from the bottom of my gas tank after removing it from the frame. What a useful wrench. Looks good too! Thankfully I've got an extra one that I keep in my toolbox for ready access.
- First Name: Rich
- Last Name: Bingham
- First Name: Neal
Re: What a useful wrench
sorry; sediment bowl! Gascolator is what it is called on an airplane fuel system! It's does the same thing.
- First Name: Dennis
- Last Name: Seth
Dennis, don't believe all you find on the internet. That tool clearly precedes the widespread introduction of metric fasteners. The end they indicate is for metric use is actually for whitworth use. The best examples cater for whitworth and BSW.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I have one similar dennis but only one sided. Mine is a 9/16 adjustable wrench
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
- MTFCA Number: 443
- MTFCI Number: 23136
Dallas, we call them ALL/16 ths
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
Y’all lookin at it wrong.
One side is for right hand use and the other is for left hand use.
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Don't ever buy one of these, for some reason it stripped everything it was tried on.
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
- MTFCA Number: 16175
- MTFCI Number: 14758
Neal, your #2335 wrench is the later version (1921-1927).
What you want for your 1915 is one of these (1913-1920). As you can see, they vary slightly in shape depending on what company supplied them.
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
I have one, but assumed it was for spark plugs and head bolts. It is 9" long so I wondered if it actually was for head bolts because is that length long enough to tighten those bolts?
Yes, that's what it's for. In the T era they didn't use torque wrenches. The #2335 wrench was long enough to tighten head bolts sufficiently and short enough to keep you from over-tightening them.
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
- MTFCA Number: 25636
Steve's right. Before torque wrenches the books would specify something like a "strong pull on an eight inch wrench" of course, a ten or twelve inch wrench would provide more leverage or "torque."
- First Name: Jeff
- Last Name: Hood
I have a "dual duty" adjustable or Crescent style wrench (I had a Boss who called them "fitzall" wrenches.) Anyway, on one side it gives the maximun opening in inches, 7/8 as I recall, but flip it over and it is 22mm. So it is both a standard and a metric "fitzall."
- First Name: Jonah
- Last Name: D'Avella
Did you work on airplanes?
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
I was always told there was a tool for every purpose and a purpose for every tool, That is a double ended adjustible open end hammer!
- Last Name: Seress
- MTFCA Number: 27707
Steve, love your sense of humor. The momma feeding the baby wrenches. Priceless. At first glance at the momma I saw the word COVID on her neck, but after enlarging the picture I saw I was wrong. It would have been even more appropriate for the times. Thank you for the laugh. Frank.
- First Name: Neal
I work for an airplane company (Cessna) and built an airplane in my garage that I fly for fun. I restored our 1915 runabout in the same spot in the garage where I built the airplane.
My 1920's version of the spark plug wrench sees more use as a wheel nut wrench on demountable rims than any other use.
- Last Name: Rosenfelder
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T touring
- MTFCA Number: 49923
I think that there many more of those wrenches about than Model Ts.
