1910-1913 rear frame to body brackets.
Posted: Tue Nov 25, 2025 6:27 am
by AndreFordT
Hi all,
I am looking for clear photos how the 1910-1913 rear frame to body brackets were attached to the frame and how this frame was build up at the rear.
Andre
Belgium
Re: 1910-1913 rear frame to body brackets.
Posted: Tue Nov 25, 2025 7:59 am
by Tbird
Andre,
There are a couple differences, between the 10-13 rear body brackets. The 1909-10 had the rear fender irons also attached to the rear body brackets they are called butterfly brackets. The 11-13 eliminated the need of the rear body brackets with the rear fender irons. The brackets are held on with three bolts two on the top and one on the side. The frames are different as well between a early frame 09-13 and a later frame after 13. These photos are of a 1911-12 frame.
- image.jpeg (102.34 KiB) Viewed 565 times
Posted: Tue Nov 25, 2025 9:30 pm
by Dollisdad
Posted: Wed Nov 26, 2025 1:14 am
by AndreFordT
Thanks all.
Now I know the way to go.
Andre
Belgium
