Help
Posted: Sat Nov 29, 2025 9:50 am
by Ron Patterson
Many years ago I posted here a copy of the Ford print for the 1/0 Model T battery/starter cables
Now I cannot find it!
Anyone got a copy you can direct me to or send me?
Ron Patterson
Re: Help
Posted: Sat Nov 29, 2025 12:44 pm
by Original Smith
Ron: I told you about the company that custom made my cables for me in Redlands. Y&Z's Yesterdays Parts. This isn't the print I know.
Re: Help
Posted: Sat Nov 29, 2025 4:16 pm
by TRDxB2
Ron Patterson
Do you mean this ? https://www.mtfca.com/discus/messages/1 ... 1302119578
Re: Help
Posted: Sat Nov 29, 2025 5:02 pm
by Ron Patterson
No.
It is a copy of a original Ford factory drawing T-1891 or T1899 battery to switch and switch to starter cables.
There is note on the drawing similar to this: "1/0 starter cable consisting of 19 strands copper wire, single covered with insulation cambric .012 inches thick. Spiral wound with minimum lap of 1/8 inch, with single stranded corded braid prepared with waterproof saturation. Outer layers of wires to be right-handed lay."
Ron P.
Re: Help
Posted: Sat Nov 29, 2025 7:07 pm
by Adam
The current reproductions would be adequate if they were the proper length and had the ends installed properly in the proper orientation…
Re: Help
Posted: Sat Nov 29, 2025 8:52 pm
by John kuehn
Ron
I’m pretty sure you know about how to obtain copies of original Ford drawings from the Ford archives. I would have thought that some where on older forum posts there might be copies but I couldn’t find them. Maybe others might could find them some where on the net besides from Ford.
They probably are available from the Ford Archives if available.
Here’s a link to it. https://www.thehenryford.org/collection ... s-drawings
