Ross steering box
Posted: Fri Dec 05, 2025 8:59 pm
by WorldChamp1914
Is Les Schubert still working on the reproduction Ross steering box?
Re: Ross steering box
Posted: Sat Dec 06, 2025 8:44 am
Posted: Sat Dec 06, 2025 10:29 am
by Les Schubert
One has been installed in a car and it has been found to be very nice to drive. Unfortunately it only fits the 26-7 T.
As part of the installation it needs a frame rail “doubler” (about 2 ft long). A easy source can be cut from another 26-7 frame. The “drag link” needs to be either twisted standard T or I’ve used a pair of model T tie rod ends and custom made piece of tubing.
I apologize for not responding earlier to people about this earlier, but I’ve been distracted with other projects
Posted: Sat Dec 06, 2025 12:12 pm
by Reno Speedster
Les,
Do you have any pictures? Is the plan to market them at some point?
Posted: Sat Dec 06, 2025 1:03 pm
by Les Schubert
I am only doing the one production run so maybe 6 will be available
Posted: Sun Dec 07, 2025 2:13 am
by WorldChamp1914
Was there a Ross steering for pre- 26-27 cars?
Posted: Sun Dec 07, 2025 11:53 pm
by KWTownsend
At one time my wife's speedster HAD a Ross steering box. Unfortunately it was removed before I bought the car for her. The Ross steering box had been replaced with a Vega steering box. It works fine. But unfortunately is not an era correct steering assembly.
Posted: Mon Dec 08, 2025 7:27 am
by Henry K. Lee
Ross steering boxes can be found in various types that are easy to adapt, ie, early Jeeps, early Willys, Crosleys, Cushman, early golf carts of various manufacturers, even old tractors used them.
Just do a little research
Posted: Mon Dec 08, 2025 9:31 am
by Jamie Maxwell
Allis Chalmers B,C, and CA tractors used both Ross and Gemmer steering gears !
Posted: Mon Dec 08, 2025 10:22 am
by Henry K. Lee
If it does not turn in the direction you require, use a bell crank from a Jeep forward cab. Just follow the 90 degree rule of steering geometry in the push/pull at the attachment points. The internet has all of this.
