Startermotor on a Openvalve Engine
Posted: Tue Dec 09, 2025 5:58 am
by ABoer
Hallo model T friends ;
A club member asked me or it is possible to put a startermotor on a Openvalve Engine .
Thank you for your answer
Toon
Re: Startermotor on a Openvalve Engine
Posted: Tue Dec 09, 2025 6:11 am
as long as it has a three pedal hogshead with the ususal shaped inspection cover over the bands, i think it is do-able. It will require a different field coil for the magneto and a ring gear on the flywheel.It is not a task to be taken lightly though.
An engineer in our T club once modified an alloy cover on his 1912 mother-in-law roadster to take a T starter motor so his wife could drive the car for herself. It took more work than just retro fitting a later cast iron hogshead, but that's what engineers do for a challenge.
Posted: Tue Dec 09, 2025 7:05 am
by Mike Silbert
Some early cars used a slightly different size / shape oil pan / hoggs head cover bolt pattern.
It also may or may not clear the teeth on the flywheel die to a slightly different shape.
Anything is possible, how much do you want to change / how hard do you want to work?
The amount of work needed and value of the original early parts is why most of the time it is just swapped for a later engine.
And the original is preserved on a stand in the corner of the garage.
Posted: Tue Dec 09, 2025 10:06 am
by JTT3
Mike is spot on. If this engine has a narrow one piece pan you’ll have to swap the pan to fit a starter hogshead. The other option if your lucky is to locate a working starter generator that mounts to the left side of the block. Most I’ve seen have a sprocket mounted on the crank & is chain driven. They are out there just need to find someone to part with it. I believe Jack Putnam had a T that he place one on. Somewhere I have a few pictures I saved. Best John
Posted: Tue Dec 09, 2025 10:18 am
Adding a battery would allow taking advantage of the "Free Start" effect. It would minimize cranking and require no invasive modification. Is the engine equipped with priming cups?
Posted: Tue Dec 09, 2025 11:42 am
by Rich P. Bingham
I will never understand the obsession with cobbling up an antique with complicated retrofit “bandaids”.
If you can’t abide your T the way it was built, drive something that pleases you. Please don’t butcher an intact, complete historic vehicle for the sake of perceived “convenience”. Driving / owning a Model T is inherently inconvenient - therein lies the interest and the fun of it. In the 21st century, a car 99 to 116 years old is NOT going to be anyone’s daily commuter car.
Posted: Tue Dec 09, 2025 12:25 pm
Do the early cars have a battery terminal on the switch?
Posted: Tue Dec 09, 2025 12:34 pm
by Rich P. Bingham
I can’t speak for the earliest coil box systems (Jacobsen/Brandow ?) but Kingston, Heinze and early KW (1910-1913) all had terminals for magneto and battery, and a “bat” switch position.
Posted: Tue Dec 09, 2025 1:55 pm
by Gleaner
Rich P. Bingham wrote: ↑Tue Dec 09, 2025 11:42 am
I agree. I am removing a late pan and hogshead starter from a restored 1909 that I purchased last year. I don’t understand wanting an early T then putting post 1918 parts on it.
Posted: Tue Dec 09, 2025 2:09 pm
One of our chapter members used to be furious when a member drove a non-T or a modern car on a tour. In later years, he could no longer drive his T, and he too would drive modern. He was somewhat less furious after that time. Now suppose you have a 1909 that you've owned and driven for many years but now can't crank it any longer. Personally experiencing that, may make us more understanding of such changes wanted/needed by others. Hopefully, such changes are 100% reversable, however ...
Posted: Tue Dec 09, 2025 2:22 pm
by Dan Hatch
What is the beauty of the way Henry made the T is just what we are talking about. You can take a 09 with a one piece pan and swap it out to a 4 dip if you want. If you ever have to take up the rods in one you will do that in a NY minute. How many times you think that was done in the good old days?
Again, to me that is what is so great about the T. It was made to keep using even as it got better each year.
Look at the junk they are making now. Buy anything and it is obsolete before you can get home.
Break is over, back to rebuilding hogs heads so they don’t leak.
Merry Christmas yous guys. Dan
Posted: Tue Dec 09, 2025 2:28 pm
Mike Silbert wrote: ↑Tue Dec 09, 2025 7:05 am
...most of the time it is just swapped for a later engine.
Adding a starter is no different,
as long as no early parts are cut-up or modified in doing so, and the original, early pieces are shelved and preserved as perhaps the whole engine may be in your comment, above.
Posted: Tue Dec 09, 2025 2:42 pm
by big2bird
I would get a starter engine complete, swap it out, and save the 09 engine for the next guy.
Easy enough to convert back later.
If you can't fix it, its not broken.
Posted: Tue Dec 09, 2025 2:52 pm
The open valve engines and drivetrains on the very early T’s should be left as is. It’s hard enough to find an open valve engine itself besides adding upgrades to it. I have 3 T’s in the so called black era and that era of T’s might be better to experiment with but not the brass era cars and especially the open valve T’s.
Posted: Tue Dec 09, 2025 3:21 pm
by big2bird
John kuehn wrote: ↑Tue Dec 09, 2025 2:52 pm
I agree John, but its his car. Perhaps he has only room for one car. The next caretaker can reverse it as well.
Posted: Tue Dec 09, 2025 6:16 pm
by Wayne Sheldon
The problem that has happened all too often with "temporarily" replacing a very early engine in a very early car with a later engine for the convenience of a starter, is that sometimes the car later gets sold and the engine does not go with the car. Sometimes this is due to whoever manages the estate sale didn't know about the engine belonging to the car and simply sold them separately. Years ago, hobbyists didn't care so much about keeping cars correct, and several times I heard of owners actually selling their early open valve engine because they had no plan to put it back into the car.
The sad irony is that however it happens, the car's later owner can spend a great deal of time and money trying to get an appropriate engine for the car, while the engine winds up with someone that spends years and money trying to piece together a 1909 car. Several times the engines wind up with someone that won't sell it (dreams of "their 1909" that never gets even half done). Often they become the legends of "I know somebody" with an open valve engine.
The worst part of separating them (whether planned or not?) is that there becomes one less proper really early model T. And that loss might become permanent.
People's situations can be different. Their finances, where they live, space for more than a couple cars?
Generally speaking, I think somebody that can afford to own a real 1909 T should be able to own and care for at least one other model T. I think any good real 1909 model T (either preservation or restoration), due to their rarity, should keep that car basically pristine. Get a 1912 to 1915 if your preference is brass era, or a black era model T to monkey with and add a starter.
I do think that real open valve early model Ts should be driven, enjoyed, and seen fairly often. But they need to be handled with care to minimize potential breakage.
Posted: Tue Dec 09, 2025 8:14 pm
by Rich P. Bingham
Agreeing wholeheartedly, Wayne. Thanks for that.
Ten years since I “returned to the fold” I have noted the graying (and the passing) of many of the knowledgeable and prominent T aficionados who have given life to this enjoyable hobby for so long. At this point, I really must protest the prevalent attitude that the owner of a car has carte blanche to do with it whatever pleases him, or whatever he finds convenient, regardless the consequences to the machine. The latest examples of the breed are now 99 years old. It should be patently clear that we who own and drive them today are mere stewards of a tangible part of the moving force behind monumental changes in daily life, from the 19th century well into the 21st.
Surely some responsibility attends this stewardship, to preserve these wonderful machines for future generations to enjoy, as we have, with the integrity of a reasonable authenticity ?
Posted: Thu Dec 11, 2025 3:24 am
by Dodge
My Dad had a 1912 Touring. During the late 1960's he bought a Gray & Davis starter/generator complete with all the electrics and battery box
for the day when he was unable to crank his car anymore. Well he passed at 95 yrs. old still cranking that car.
The Gray & Davis is still sitting on the shelf waiting for the day when I can't crank my Brass T anymore......
Let's see if I can still do it when I get old, I'm only 75 now and cranking and been cranking that car for 60yrs. I really like cranking that old
girl.
Posted: Thu Dec 11, 2025 10:13 am
I'd see how skilled I could become at obtaining "free starts" with little or no cranking needed. Parking the car on a slope to allow a "rolling start" is another option in many areas.
Posted: Thu Dec 11, 2025 6:26 pm
I made a discovery these last two days doing my usual promotion rounds for the Chocolate company in my 1912 van. I used to hand crank it with feet square to the front axle, engaging the crank handle at 9.00 o'clock and giving a quick but determined pull upwards over one compression.
When parked in one spot a thoughtful driver left me just a foot or two of room in which to do this. I was forced to stand side on to the car and simply lift on the handle as I rocked back. It requires much less effort The weight of the body falling back does all the work for you. No more heaving for me. My shoulder appreciates the lack of effort. Repeating the action is also no great strain.
Posted: Thu Dec 11, 2025 6:34 pm
Interesting...
Posted: Thu Dec 11, 2025 9:20 pm
by Rich P. Bingham
Allan, that’s a useful revelation. I’m not understanding thoroughly - could you explain, please, with a bit more detail ?
An aside, cuz that’s what geezers do, ramble on.
When I had my first T, I was a skinny little slip of a 14 year old. I could spin my sometimes recalcitrant mount like a hurdy-gurdy. One time, a school mate in a grade above me, football player and outweighed me by half again wanted to crank my T. He’d seen me spin the crank and figured it wasn’t much. He could barely do it, he didn’t have the knack I had developed, balance and timing. No doubt he was natively much stronger, but there’s a trick to cranking easily.
Posted: Thu Dec 11, 2025 11:47 pm
ABoer wrote: ↑Tue Dec 09, 2025 5:58 am
Toon
Get in touch with Ed he may have all or most of the parts you need
Posted: Fri Dec 12, 2025 6:07 am
Rich, I am right handed. previously I faced the car, steadied myself on the fender/headlight with my left hand, and cranked with the right. Pulling upward from 9 o'clock for one compression, using my legs and shoulder to drive my right arm. It is my shoulder which was giving me trouble of late, that and reduced power at 79.
Standing side on facing left, right hand still for cranking, it just is much easier to use my body weight to help drive the cranking. It's a bit like falling over, in well controlled movement. It takes so much less effort to crank this way.
When my van has been standing for months, the start-up is as follows. Crank over four throws with the choke fully closed to prime the motor. Then switch on the ignition. It usually starts first pull then. During the day, with repeated stops around the city, it will start easily, with no choke, usually on
the second pull. At the end of such a day, anything which makes it easier is most welcome.
Obviously, others do it differently.
Posted: Fri Dec 12, 2025 7:27 am
by AndreFordT
Just my opinion,
It is at the owner of the car to dicide if he want an electric starter or not on his car, even if it is a car before the starter area.
I did this for me on my three Model T (1926; 1922 and 1915).
The raison was easy:
In 2010 I had my third back surgery with a fusion between L3 and S1. Now 15 years later the back pain is still there every day.
The surgery made me walk again but it didn't replace or repair my bad back.
One of the problems was and is still the cold crank start of my Model T's. There for I have an electric starter on all my cars and yes also on the 1915 touring.
In the past, I did this on a 1912 right hand (English) Touring and a 1911 Torpedo.
For the touring I changed all the needed parts on the original engine. (Thanks Toon for the Hoghead.)
For the 1911 Torpedo, as it is a weekly driven car (also in the winter), I rebuild a complet 1919 engine and swaped it with the original 1911 engine (not open valves engine). The orginal engine is stocked in a dry warm garage and surely not for sale, it will stay with the car.
Just my opinion.
Toon I see you next Saturday at Bergambacht during the technical afternoon.
Andre
Belgium
Posted: Fri Dec 12, 2025 9:39 am
Replacing the early engine with a later generator/starter engine/transmission that is balanced has advantages if the car is driven often. A well-balanced powerplant will reduce structural stress from vibration on the rest of the car. I'd want the early engine to stay with the car.
