Advice removing stuck head light rim
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Tue Jul 09, 2019 12:55 pm
I have lubricated rim front and rear with wd-40 I bought the rim removal tool No luck It seems the problem is the rim will not push in to any degree therefore not releasing the lug cut out on the light bowl. Any suggestions? I have been pushing in hard with the tool and see only a tiny movement back
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: Advice removing stuck head light rim
Post by MichaelPawelek » Tue Jul 09, 2019 1:14 pm
They can be very tough to remove. Have someone get behind the bucket to stabilize it so you can push in harder from the front.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Tue Jul 09, 2019 2:03 pm
Also, put a pillow or some towels on the ground under the headlight bucket to catch the lens if it comes out when the rim pops free. :)
Jeff Hood
Last Name: Hood
MTFCA Number: 25636
Post by Jeff Hood » Tue Jul 09, 2019 2:04 pm
Take it off the car and put it face down on a rubber mat such as a mudflap. Now you can use your full body weight to push the bucket into the rim and turn it with the leverage of the mounting arm.
MTFCA Number: 28924
Post by John kuehn » Tue Jul 09, 2019 2:05 pm
Have you tried pushing in one lug at a time individually? I had a real tough one once and concentrated pushing one lug at a time after lubing it well with WD40. Once you get it slightly moving then try to turn the rim. It was really tough but it finally started moving.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jul 09, 2019 3:28 pm
I do as Jeff suggests - only one nut holding it to the fender iron !
Last Name: House
Post by George House » Tue Jul 09, 2019 6:15 pm
Thin screwdriver !! First put blankets or quilts on the ground in front to catch the lens when it pops loose. I’ve done this many times. Stick the thin screwdriver under the rim close to the top rivet. Pry the bucket ‘cam’ area down while gently pulling the circular rim forward. It’ll pop loose and no part will be distorted. Then do the same to the outside (toward fender) rivet. It’ll be easier. Then the headlamp rim can be removed.
I’d Rather Suffer Much In Good Company Than To Live Comfortably With Delicate Men..
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Tue Jul 09, 2019 6:31 pm
Thank you all!!
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Tue Jul 09, 2019 8:42 pm
This is the method I use. I've got Liberty lenses in my headlights which are shaped differently to the Ford lenses; the result being the rims can't be pushed back sufficiently to disengage them the normal way.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Jul 09, 2019 11:11 pm
Post by Mark Gregush » Wed Jul 10, 2019 9:40 am
I take mine off and do the rubber mat trick except I use carpet. Another advantage of doing it that way, good time to clean the ground path at the mount.
I know the voices aren't real but damn they have some good ideas! :roll:
1921 Huckster
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Wed Jul 10, 2019 12:52 pm
Where do you find them?
cessna53195
Last Name: Skingley
MTFCI Number: 23002
Post by cessna53195 » Wed Jul 10, 2019 1:32 pm
A hint for re-assembly is to lubricate with wax, works great for the large surface area. Excess wipes of easy and is friendly with paint. You can buy a new ring of toilet bowl wax and leave on the work bench about $3 bucks. Works for many projects, I use it when mounting tires, spring lube, threads etc...
Altair
First Name: David
Last Name: Menzies
MTFCA Number: 27825
Board Member Since: 2012
Post by Altair » Wed Jul 10, 2019 3:24 pm
I have used this style of rim remover with good success.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Jul 10, 2019 4:39 pm
Dave-
Have a friend come help you. Sometimes if you use four hands to squeeze at the rivet release points it will come loose.
You might want to check with Michael Pawelek to see if his two neighbor ladies are available...
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Jul 10, 2019 6:43 pm
Keith, I can’t believe you remembered my post from almost 25 years ago. I caught a bunch of flack from the forum group when I “borrowed” two of my neighbor’s wives to help me get my headlight rims off! Yes, they were great with their hands but I swear no hanky panky happened........ :)
Post by TRDxB2 » Wed Jul 10, 2019 8:13 pm
Just got two '26 headlight buckets. Before attempting to remove the headlight rim I went around it squeezing/kneading it against the bucket. I focused more on the area where the rivets are. This took several revolutions before I could feel the spring in the headlight reflector getting compressed. Then I got another pair of hands (Grandson's: neighbor ladies not home yet) and with each hand placed on the rim above a rivet we pressed down and rotated it counter clockwise. Came off easily. I think the secret is to make sure you are able to compress the spring all the way around the rim before trying to rotate it. Yes 4 hands make it easy.
Tiger Tim
Last Name: Eckensviller
Post by Tiger Tim » Thu Jul 11, 2019 7:52 pm
...two of my neighbor’s wives...
How many wives does this neighbour have?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Jul 11, 2019 8:39 pm
Don’t know but he always has a big grin on his face! :)
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Thu Jul 11, 2019 9:19 pm
My right one operates smooth as silk. The left one turns easy enough, but is hard to get off. I have done the little screwdriver trick and it works. I believe the reflector is turning and getting in the way of the pins, FWIW. :)
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Fri Jul 12, 2019 8:30 am
It took me almost two hours to get my rims off the first time. My reproduction rims had pins of various heights and some were too long to allow removal. I filed all pins to the same height and can now remove rims whenever needed.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Jul 12, 2019 12:08 pm
All the repro rims I've worked with had all 4 rivets too long - shortened them all with a Dremel w/cut-off wheel to equal lengths.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Jul 12, 2019 7:13 pm
Finally, someone mentioned the correct way to turn the rim for removal! I would never use one of those tools, unless you want to ruin the paint on your rims, but if you have a '15 maybe it doesn't matter quite so much.
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Sat Jul 13, 2019 11:45 am
My thanks to all !!! Usinf two thin bade straigt screw drivers I was able to carefully pop the side rivit bumps, then the top It came right off!! So much for my new 30 dollar tool !!!!
