4th Main Oil Hole Details
Posted: Wed Jan 07, 2026 6:03 pm
by MossPointMachine
Can someone help with the size and location to redrill the 4 th main oil hole, measurement from shoulder would be good. Trying to finish an engine my Dad built for me before he passed away. I can’t see any trace of the hole in the shell he had re babbited. Thanks
Re: 4th Main Oil Hole Details
Posted: Wed Jan 07, 2026 6:31 pm
The hole is in the middle of the collar, about 3/8" with an oil cut forward & aft to lube a larger surface of the shaft. (but short about 1/2" from the output shaft end)
I also caution you that your indicator in not in the correct place for centering.
Only the narrow machined area next to the flange face is correct for perfect centering.
Posted: Wed Jan 07, 2026 6:54 pm
by MossPointMachine
Thanks for your prompt reply, yes I did indicate the flat land next to the mounting flange. I had read that in another post. Appreciate the help.
Posted: Wed Jan 07, 2026 9:43 pm
by RGould1910
Seen a lot of 4th mains but never an oil cut. I don't think it's necessary but it's not a bad idea. Don't believe they came that way from the factory tho.
Posted: Wed Jan 07, 2026 11:57 pm
Posted: Thu Jan 08, 2026 8:18 am
I disagree with the clearance specs as provided. Way too loose.
4-6 will pass a lot of oil into the U-joint especially if you are using a transmission screen.
.0015-.002 is what I fit to in this part with babbit, same as for rods & mains.
