1924 fender to running board question
Posted: Fri Jul 12, 2019 3:15 pm
by cwlittle
I understand that instead of a wooden block between the front fender and running board there was two "spacers". Were these essentially thick washers? And how thick were they?
Re: 1924 fender to running board question
Posted: Fri Jul 12, 2019 6:41 pm
by sweet23
Yes the earlier fenders had a washer between the fender and the running board. In '25 the fenders were modified to have a raised area around the bolt holes, eliminating the need for the washer. R. V. Anderson makes a bolt kit for the fenders & running boards that has the correct washer included.
Posted: Fri Jul 12, 2019 6:57 pm
by Original Smith
Just use a relatively thick 5/16" washer about the same diameter as a quarter.
Posted: Sat Jul 13, 2019 7:11 am
by cwlittle
THANKS for the info!
