Stewart speedometer
Posted: Sat Jan 31, 2026 4:07 pm
by BillM
Am I correct that this swivel is made In October 1919 and is a 6:1 ratio? If so would it be correct to use on a 1923 coupe?
Re: Stewart speedometer
Posted: Sat Jan 31, 2026 4:59 pm
Russ Furstnow is the speedometer guru (He wrote the book.). If he doesn't see and answer this post, maybe you can contact him through the forum (or Google).
Posted: Sat Jan 31, 2026 6:39 pm
I believe that is a left hand drive & the ratio is 2 & 1/2 to 1.
Posted: Sat Jan 31, 2026 7:28 pm
by Russ_Furstnow
The Stewart Model 1962 swivel is a 6:1 RH ratio. It goes on a 1915-17 Hudson. You need a Model 1913 Stewart swivel for your Ford. I hope this helps. Russ Furstnow
Posted: Sat Jan 31, 2026 8:39 pm
Thanks for the correction, Russ - I was under the impression that Stewart swivels were 2 & 1/2 to 1.
Posted: Sat Jan 31, 2026 10:03 pm
by BillM
Thank you for that information Russ! I'll be on the lookout for a 1913.
Posted: Sun Feb 01, 2026 2:54 am
On our RHD cars, the swivel is often mounted on the other side to the LHD cars.Same ratio as the pn 1913 but opposite rotation. If you can't find a decent 1913 swivwl, and your cable and housing is long enough, the swivel can be mounted on the opposite side of the car. Without getting into my spares, I cannot recall the PB for this alternative swivel. Perhaps Russ knows.
Posted: Sun Feb 01, 2026 8:48 am
by Russ_Furstnow
Nearly all of the pot metal Stewart swivels look alike, but there are a variety of ratios (from 1:1 to 12:1) and RH and LH types. The 2.5:1 LH part number is Model 1959. Most applications take the Model 1913. I hope this helps, Russ Furstnow
Posted: Sun Feb 01, 2026 11:26 am
by BillM
Yes it helps a lot. I'll find one somewhere. At least now I know what im looking for. I really appreciate your help guys!
Posted: Sun Feb 01, 2026 11:26 pm
A questions for Russ. The Stewart potmetal swivel housings are the weak link in the Stewart swivels I have found. Can components from LH swivels be swapped into RH swivel housings? Are swivels housings for different ratios interchangeable for other ratio components. This may/may not enable a good swivel to be mix and matched from models.
Posted: Mon Feb 02, 2026 8:20 am
In my experience, the pot metal housings are interchangeable.
Posted: Mon Feb 02, 2026 8:44 am
by Russ_Furstnow
John is correct. The pot metal housings are identical. The inner gears determine the ratio of the unit. I have new sets of gears that turn any Stewart swivel into a 2.5:1 RH swivel. These new gear sets were manufactured using original Stewart gears as a pattern. I hope this helps, Russ Furstnow
Posted: Mon Feb 02, 2026 11:09 am
by BigAl
Bill, Sent email through the forum.
Posted: Mon Feb 02, 2026 8:30 pm
Thanks for the confirmation re parts swapping Russ. i suspected it was the case. I guess then that the only difference of consequence is the threaded lower half and the lock nut on the later housings rather than the plain pin with the pressed on collar.
Your spare gear sets will undoubtedly keep many users happy.
Posted: Tue Feb 03, 2026 10:25 am
by Harley_97
I got this Stewart gear with some T items I bought awhile back. I don't see any signs that it has ever been used. The question, is this gear for Model T's or something else.
Thanks Roger
Posted: Tue Feb 03, 2026 4:19 pm
by Russ_Furstnow
The gear is a 16T9P (#2302) pinion gear. It was not used on a Ford but some other automobile. The Ford uses a 16T8P pinion gear (#2301). I hope this helps, Russ Furstnow
Posted: Wed Feb 04, 2026 9:08 am
by Harley_97
Thanks Russ.
