Knock Knock
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
- MTFCA Number: 295
- MTFCI Number: 127
Knock Knock
for three years I have tried to trace down a knock that has bugged me since I built it.
Think I found it.
Think I found it.
- First Name: Keith
- Last Name: Gumbinger
- MTFCA Number: 4661
- MTFCI Number: 6866
Re: Knock Knock
Dean, It's great that you finally found it, but are you going to share what you found with the rest of us?
Thanks,
Keith
Thanks,
Keith
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Re: Knock Knock
I am guessing it was the use of plywood behind the electrical panel (?).
- First Name: Les
- Last Name: Schubert
Re: Knock Knock
Having no information, I’m guessing cam shaft end play!! It can really drive you crazy!!
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
After I drive it and am positive what it was I will share .no one has hit it yet
- First Name: Tony
- Last Name: Howard
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tourer 1925 Coup
Re: Knock Knock
Do you have a "friend" like this????
https://www.youtube.com/watch?v=LONT1oboJrs
Government - because people struggle to ruin their lives by themselves
- Last Name: van Ekeren
Re: Knock Knock
Now I'm sure everything would have been sweet when Dean rebuilt the engine so I'm putting my money on a sneaky little knock on the scat hitting the pan horse shoe or one of the bolts holding it.
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
Not the scat crank hitting .checked that couple years ago.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Knock Knock
Rod bolt barely tapping the cam? Loose flywheel bolt?
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
Not the rods. I have checked them three times
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
Flywheel bolts so tight I thought I was going to have a cheater bar to get them off.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: Knock Knock
Had one that drove me nuts, .060 over Egge's with the sharp edge on side was hitting head gasket, Another one was piston hitting top of cylinder on high rpm's with High Compression head.
- First Name: David
- Last Name: Dufault
- * REQUIRED* Type and Year of Model Ts owned: 1915
- MTFCA Number: 303
Re: Knock Knock
Ohhhh - the suspense....
Anxiously awaiting the answer...
- First Name: Verne
- Last Name: Shirk
Re: Knock Knock
Bent rod or piston slap?
- First Name: Harold
- Last Name: Schwendeman
Re: Knock Knock
Crankshaft pulley/pin assembly?
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
Removal of one shim cured my knock.
Re: Knock Knock
Sounds like you were lucky that your engine didn't eat the magneto
- First Name: David
- MTFCA Number: 303
Re: Knock Knock
Interesting.
So, for further education, why was the shim installed? For some reason it was put there....the result was not to your liking - (nor to the engine's)...is there a lesson to be learned here that you can share with us?
Incidentally - many thanks for the expertise you have shared in the past!
Dave
Dave
- First Name: DEAN
- Last Name: YODER
- MTFCA Number: 295
- MTFCI Number: 127
Re: Knock Knock
Dave the biggest lesson is 25- 40 clearance loose
25.
The shim I used is a factory shim.
I made it too tight.
Scat cranks have a large radius fillet if I am setting another scat. On the tight end I will check my radius fit with plastigague.
25.
- First Name: David
- MTFCA Number: 303
Re: Knock Knock
Thank you.
Another lesson I hope to file away between my ears. (But I will write it down to count for the inevitable "forgetfulness"
