Knock Knock
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Knock Knock
Post by D.Yoder » Sat Jul 13, 2019 6:11 pm
;) for three years I have tried to trace down a knock that has bugged me since I built it.
Think I found it.
KeithG
First Name: Keith
Last Name: Gumbinger
MTFCA Number: 4661
MTFCI Number: 6866
Re: Knock Knock
Post by KeithG » Sat Jul 13, 2019 6:21 pm
Dean, It's great that you finally found it, but are you going to share what you found with the rest of us? :)
Thanks,
Keith
'14 Touring, '26 Roadster Pickup, '27 Fordor, '25 TT C Cab with Express Bed.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: Knock Knock
Post by Burger in Spokane » Sat Jul 13, 2019 6:29 pm
I am guessing it was the use of plywood behind the electrical panel (?).
Les Schubert
First Name: Les
Last Name: Schubert
Re: Knock Knock
Post by Les Schubert » Sat Jul 13, 2019 6:42 pm
Having no information, I’m guessing cam shaft end play!! It can really drive you crazy!!
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Sat Jul 13, 2019 7:24 pm
After I drive it and am positive what it was I will share .no one has hit it yet :D :D
Tony_H
First Name: Tony
Last Name: Howard
Re: Knock Knock
Post by Tony_H » Sat Jul 13, 2019 7:33 pm
Do you have a "friend" like this???? :lol:
https://www.youtube.com/watch?v=LONT1oboJrs
Government - because people struggle to ruin their lives by themselves
Kerry
Last Name: van Ekeren
Re: Knock Knock
Post by Kerry » Sat Jul 13, 2019 8:11 pm
Now I'm sure everything would have been sweet when Dean rebuilt the engine so I'm putting my money on a sneaky little knock on the scat hitting the pan horse shoe or one of the bolts holding it. :D
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Sat Jul 13, 2019 10:39 pm
Not the scat crank hitting .checked that couple years ago.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Knock Knock
Post by Adam » Sun Jul 14, 2019 9:37 am
Rod bolt barely tapping the cam? Loose flywheel bolt?
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Sun Jul 14, 2019 12:05 pm
Not the rods. I have checked them three times ;)
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Sun Jul 14, 2019 12:12 pm
Flywheel bolts so tight I thought I was going to have a cheater bar to get them off.
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Re: Knock Knock
Post by Joe Bell » Sun Jul 14, 2019 5:31 pm
Had one that drove me nuts, .060 over Egge's with the sharp edge on side was hitting head gasket, Another one was piston hitting top of cylinder on high rpm's with High Compression head.
aDave
First Name: David
Last Name: Dufault
MTFCA Number: 303
Re: Knock Knock
Post by aDave » Tue Jul 16, 2019 10:27 am
Ohhhh - the suspense....
Anxiously awaiting the answer...
Shirkwood
First Name: Verne
Last Name: Shirk
Re: Knock Knock
Post by Shirkwood » Tue Jul 16, 2019 10:53 am
Bent rod or piston slap?
HaroldRJr
First Name: Harold
Last Name: Schwendeman
Re: Knock Knock
Post by HaroldRJr » Tue Jul 16, 2019 8:58 pm
Crankshaft pulley/pin assembly?
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Tue Jul 16, 2019 10:34 pm
Removal of one shim cured my knock.
Kerry
Re: Knock Knock
Post by Kerry » Wed Jul 17, 2019 12:26 am
Sounds like you were lucky that your engine didn't eat the magneto :D
aDave
First Name: David
Last Name: Dufault
MTFCA Number: 303
Re: Knock Knock
Post by aDave » Wed Jul 17, 2019 9:45 am
Interesting.
So, for further education, why was the shim installed? For some reason it was put there....the result was not to your liking - (nor to the engine's)...is there a lesson to be learned here that you can share with us?
Incidentally - many thanks for the expertise you have shared in the past!
Dave
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 20778
MTFCI Number: 127
Re: Knock Knock
Post by D.Yoder » Wed Jul 17, 2019 1:33 pm
Dave the biggest lesson is 25- 40 clearance loose
25.
The shim I used is a factory shim.
I made it too tight.
Scat cranks have a large radius fillet if I am setting another scat. On the tight end I will check my radius fit with plastigague.
aDave
First Name: David
Last Name: Dufault
MTFCA Number: 303
Re: Knock Knock
Post by aDave » Wed Jul 17, 2019 2:57 pm
Thank you.
Another lesson I hope to file away between my ears. (But I will write it down to count for the inevitable "forgetfulness"
