Exhaust pipe heat
Topic author - Posts: 163
- First Name: Jeff
- Last Name: Schroeder
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
- MTFCA Number: 50300
- MTFCI Number: 87
Exhaust pipe heat
Do any of you think there would be a problem if I wrapped the exhaust pipe (with fiberglass wrap) to cut down on the heat coming up through the floorboards? It's a '16 Touring. Thanks,
Jeff in Florida
Jeff in Florida
1916 Touring
- First Name: Phillip
- Last Name: Lee
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster Pickup
- MTFCA Number: 50230
Re: Exhaust pipe heat
I wrapped my exhaust pipe just under the floor board on my 27 Roadster Pickup and have had no issue. The floor is cooler. It is lots easier to remove the exhaust to wrap it.
Phillip
Phillip
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
- MTFCA Number: 50356
I just did exactly the same thing using titanium wrap (the titanium has a higher max temp and is easier to install).
It smokes pretty good the first time it heats up so just be aware of that.
As far as whether it works, I don't know yet.
- First Name: Rick
- Last Name: Ross
Mine is wrapped. Smoked for a few minutes and no issues since. Good luck!
- First Name: Rolf
- Last Name: Oehman
Or you could use an aluminium shield mounted with spacers and wood screws under the floorboards. Two pieces . One for each floorboard.
- Last Name: Zibell
- MTFCA Number: 30265
- MTFCI Number: 24046
I have wrapped my stainless pipe with exhaust wrap. I wouldn't wrap regular steel as the wrap can hold moisture increasing the rust rate of the pipe. I also stapled automotive insulation to the bottom side of my floor boards. Doing both make a big difference.
1926 Tudor
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
I did both. Exhaust pipe wrap and I made a heat shield
- Attachments
- 284DAE21-F5D5-4EB5-8323-CEAF2B9ED8A1.jpeg (66.46 KiB) Viewed 4782 times
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
I used a piece of 4" flexible metal dryer hose cut in half to fit over the pipe as a heat shield. It was easy to form and wire in place.
1912 Torpedo Roadster
- First Name: Rolf
- Last Name: Oehman
Ps:Sorry Had to repost this due to the website transfer the picture got lost.
- First Name: Neil
Repost of picture
- Attachments
- A16EFECC-8A04-45F3-BDA8-C8BD25E44FB4.jpeg (66.46 KiB) Viewed 4525 times
