Good source for Wooden Steering Wheel Rims
Posted: Sat Feb 21, 2026 11:18 pm
by OilyBill
Anyone know a good source for wooden steering wheel rims, such as on early Ford cars, or Model T's? The kind that nest into the 4 spider spoke ends, and are held in place with a screw on each arm of the center spider? I need to find a source for a wooden rim for two 1912 Overland automobiles. The original deteriorated rims were wood, and are just 1/2" larger in diameter than a Model T steering wheel rim, so I cannot use a Model T wood steering wheel, but they are virtually identical in style and shape of the wood rim area. Anyone know someone who made a Model T wood rim for them, and could make a slightly different size?
Thanks to all!
Re: Good source for Wooden Steering Wheel Rims
Posted: Sat Feb 21, 2026 11:54 pm
by South Park Zephyr
Do you have a diameter?
I have a few wooden wheels that are not T’s
Scott
Posted: Sun Feb 22, 2026 7:00 am
by rickd
Snyders carries a good selection of finished steering wheels. Maybe they can help you?
Posted: Sun Feb 22, 2026 7:08 am
by gldavis
I bought a steering wheel from this vendor several years ago, and I've been very happy with it.
https://woodbykevinallen.com/model-t-st ... heels.html
Posted: Sun Feb 22, 2026 9:52 am
by TMiller6
Noah Stutzman can also make wooden steering wheel rims. Years ago he told me if I bring him the metal spider, he can go from there.
It’s also fairly easy to make your own by cutting 16 pieces of wood and gluing them with overlapping joints. I made it round by using a router bit and a turntable on my drill press.
Posted: Sun Feb 22, 2026 1:19 pm
I have these that are not Model T wheels if they might be what you are looking for
Scott
Posted: Sun Feb 22, 2026 1:21 pm
One more that wouldn’t fit with the previous post
Scott
Posted: Sun Feb 22, 2026 2:42 pm
by kmatt2
I have had good luck with Kevin Allen , at Wood by Kevin Allen , he does excellent work and can make a custom wood wheel to fit your stock steering wheel spider, provided you have a spider for your car that you can send him. I see that Kevin’s contact information has already been posted in this thread, so check above for that information .
Posted: Sun Feb 22, 2026 3:09 pm
by Jack Putnam, in Ohio
Noah Stutzman. Makes steering wheel wooden rims. Made from a single piece of steam bent wood with a finger joint. He can make them round, oval with or without finger grips. Excellent Amish craftsmanship. Stutzman wheel shop 330 897 1391, Baltic, Ohio
Posted: Sun Feb 22, 2026 7:38 pm
by Tmooreheadf
I agree with Jack. Noah has done two for me. His work is great. He let me select the wood I wanted. Sent the spider to him and he did the rest! Outstanding service and quality!
