Re: Balloon tires
Posted: Fri Feb 27, 2026 6:41 am
by Luxford
The only balloon tires mentioned over the years appear to be the normal 21 inch variety.
But there were aircraft style balloon tires also available in the T era. In 1923/24 the balloon tire was taking hold. The makers of Buffalo wheels had available larger section baloon tires. Here is an ad from Ford Owner Dealer January 1924 it mentions 30x 3/12 wheels so they were obviously offering them to Ford owners.
These wheels in disc form were adopted by the Army and the Marines on vehicles they were adapting for use over rough ground.
Something they began looking at after WW1 before the Jeep was developed when WW2 arrived.
Has anyone come across such disc wheels on a Model T or the remains of one?
Attached a photo of the Army's version in tests in 1926.
the Owner Dealer ad from 1924 and close up of mention of the tire sizes.
Re: Balloon tires
Posted: Fri Feb 27, 2026 7:00 am
by Dan Hatch
TT had a larger front tire size that was either aftermarket or an option. If I remember correctly it was the size listed in the ad.
Was not a clincher. Just regular tire. The rim fit a standard 30x3.5 wheel. Only have seen one set. Sold the rims to someone in Luray Va many moons ago.
Re: Balloon tires
Posted: Fri Feb 27, 2026 10:11 am
The term "Balloon tires" in the T era typically referred to any low pressure tire, including those which look very skinny to us today, such as the 4.40/4.50 X 21 tires. Prior to around 1928, tires were usually 3" to 4" in nominal width, with tread around 3" wide, if any tread was present, and tire pressures were typically in the 50 to 65 PSI range. Balloon tires, besides being wider, and of somewhat different construction, could be run at pressures in the 25 to 30 PSI range. All sorts of aftermarket and specialty tires and wheels were on the market, but most of them never came into wide use. A look at Ford's advertising in the late T era will show what Ford offered as standard and optional wheel and tire equipment.
