Ring and pinion gears
Posted: Mon Mar 09, 2026 3:26 pm
by Oldrusty26
Hello all !! Are the ring and pinion gears the same between the small drum and the large drum
Re: Ring and pinion gears
Posted: Mon Mar 09, 2026 3:46 pm
Sure are !
Posted: Mon Mar 09, 2026 3:48 pm
by Mike Silbert
Old Rusty,
The Ford ring and pinion is interchangeable 1909-27.
Ruckstell made special rings and pinions that are not interchangeable with the Ford ones.
The differential carrier and spider gears changed through the years but are interchangeable in sets.
Mike
Posted: Mon Mar 09, 2026 6:18 pm
by Oldrusty26
Thanks Mr Silbert !! Appreciate your help. Working in a 25 and the ring gear is toasty
Posted: Mon Mar 09, 2026 6:36 pm
Mike Silbert wrote: ↑Mon Mar 09, 2026 3:48 pm
Old Rusty,
Mike
Well........ Not exactly.
There are ring & pinion gear sets produced with a slightly different tooth angle.
They are marked with about an 1/8" round dimple on both gears. They are not to be mixed with non dimple marked gears.
I believe there was a service bulletin warning to this effect.
Posted: Mon Mar 09, 2026 6:46 pm
by Kerry
I haven't come across any of the late USA Ts having the dimple marked gears but have in the Canadian Ts, Canadian service bulletin in 1923 shows them as new design drive gear and pinion.
Posted: Mon Mar 09, 2026 6:55 pm
Kerry wrote: ↑Mon Mar 09, 2026 6:46 pm
I have several sets & loose individual gears I have acquired over the years.
I don't know how they made their way to the swap meets. I acquired them in the USA.
I know enough not to mix em from a service bulletin. Something to be aware of.
Posted: Mon Mar 09, 2026 7:22 pm
by Pep C Strebeck
This is the Service Bulletin in question:
- 924515.png (205.38 KiB) Viewed 355 times
- 924514.png (226.82 KiB) Viewed 355 times
I have tried to match the ones that I have together in sets and identify them as such.
Posted: Mon Mar 09, 2026 7:28 pm
My mum taught me to avoid anything with spots on. Now you guys say it's OK in given circumstances!
Posted: Tue Mar 10, 2026 8:21 am
by Mike Silbert
Not being a Canadian car guy I have never seen spotted ring gears or heard of them.
I also have never seen or read Canadian service bulletins.
I did read the American service bulletins cover to cover as a kid 50 years ago, what was I thinking.
Maybe I live too far from the border.
There is always something new to learn about the Model T Ford.
Mike
