Clutch lever adjusting bolt
Posted: Sun Jul 14, 2019 4:42 pm
by 70shovelhead
Can someone provide the dimentions and TPI of the clutch lever adjusting bolt.
Re: Clutch lever adjusting bolt
Posted: Sun Jul 14, 2019 5:09 pm
p/n 3403 is 3/8" - 24tpi x 1 5/16". Can also use Fan adj. screw, p/n3973.
Like to turn the bolt head upside down, and grind the hex a bit rounded as that make a wider surface for contact on the controller shaft. Add some grease too.
Posted: Sun Jul 14, 2019 5:19 pm
by 70shovelhead
Perfect, thanks Dan
