Trouble in the transmission, what's up?
Posted: Thu Mar 19, 2026 4:10 pm
by DanTreace
Have been investigating today the source of rather disturbing noises from the transmission of my '27 touring.
Noise presented out of the blue on January 28th, had run about 2 miles to a friends home, parked and couple of hours later started fine, ran normal speed about 30 back to the house and on arriving to park in the garage.
But the reverse was very rubble loud. And then when going into low pedal, clutch lever forward, same growl and rattle with jerking and stumble.
Something is wrong in the transmission.
Here is the video made on the day in January, fearing more damage if driving, so parked it, and have later removed the engine to do a " post mortem"
https://youtu.be/nAD98o0fCnE?si=tbNn7mQteuCXdjhF
After reviewing, anyone suggest what is the internal issue(s)?
After a few guesses, of those who wish to , I will post our photo findings made this morning
Re: Trouble in the transmission, what's up?
Posted: Thu Mar 19, 2026 4:33 pm
by Allan
I once broke a pinion gear tooth off. Going down the road i could hear a faint ticking that others unfamiliar with the car would never have picked. The louder noise only came on trailing throttle. under brakes and when reversing.If you have found yours. it is not a busted pinion gear!
Posted: Thu Mar 19, 2026 5:04 pm
by speedytinc
How long has this motor been in service?
Triple gear issue.
Acts like a seized/seizing triple gear bushing(s).
Before removing the motor, I would confirm thru the inspection cover.
Posted: Thu Mar 19, 2026 5:20 pm
by DanTreace
speedytinc wrote: ↑Thu Mar 19, 2026 5:04 pm
Triple gear issue.
About 3,500 miles on total rebuilt, all new parts, scat crank, pistons, rings, including all three new repro drums, triple gears, pins, turbo discs, etc.
Did look at triple gears inside the inspection port, nothing seized, loose or rocking at that view.
Posted: Thu Mar 19, 2026 5:32 pm
by John kuehn
For a time as I remember if you were buying the new drums you could use your own drum gears if they still pretty good. Maybe now you can buy a complete new drum. If you used your own drum gears maybe a rivet or more has gotten loose? Just a guess.
Posted: Thu Mar 19, 2026 5:40 pm
by speedytinc
In your 27?
Spiral split brake drum shaft.
Posted: Thu Mar 19, 2026 9:59 pm
by DanTreace
Thanks for the insights on the noise.
Thought too the triple gears, so when inspecting after disassembly, every thing was pretty ok, clutch spring and drum ok, the turbo discs without wear, but when revolving the drums, there was a bit of catch as the brake drum was rotated.
Peaked at each gear revolving and found this
Click on photo to enlarge.
So lifted off the drums and took closer look.
Haven't had this occurrence before, the new driving gear cracked in two pieces, right at the key slot corners. That was the jerky rattle alright!
At least the flywheel recess kept the two pieces together, not sure how long it ran before both sides let go, perhaps the gear ran for a while with one side cracked?
So fix will be to replace the gear with a new one, not sure why this driven gear failed in short time, engine built and put in service May 2022, had about 3500 miles or so on it. Couldn't find a Ford marking on its so guess its a repop gear.
Posted: Thu Mar 19, 2026 10:13 pm
by TXGOAT2
It may be that the gear was defective, or it could be that a problem in the u-joint, driveshaft or rear axle put a shock load on it, causing a fracture. I'd do some checking on the driveline downstream of the new transmission.
Posted: Thu Mar 19, 2026 10:27 pm
by RajoRacer
I have a drawer full of good used ones, if you need one Dan - pay the postage.
