Firewalls and speedster ideas
Posted: Tue Mar 24, 2026 10:59 pm
Is a metal firewall a hood former on a speedster or would a metal cowl over it be the hood former?
I have a metal cowl with the curved down sides that extend back to the seat area I believe from a speedster hanging in the garage. It appears to fit to a metal cowl so I am guessing about a 23. I also have a 23 engine and a chassis that are taken apart and stored and have been thinking about trying to put together and possibly make a speedster. If a hood was to be put on it what does the back of the hood sit on? Would not have to worry about it I did not use a hood.
Would have to put a floor under the body as there is just a lip around it. I have some 3/4 inch oak veneer cabinet grade plywood that would make solid floor. Does a person just use wood screws to attach the body lip to the floor or use machine bolts washers and nuts going completely thru the floor to secure it?
Also do you bolt body mounts to the bottom of the floor or bolt it with support pads to the mounts on the frame?
I do not want to lower the frame due to personal preference.
Maybe I am just a dreamer but we live longer and we keep active in our mind and body and do work on things we enjoy.
