STRANGE ENGINE NOISE
Posted: Wed Mar 25, 2026 10:34 pm
I’ll try to make this description short. The engine goes in a ’27 Tudor. Numbers match.
• The engine was rebuilt 11 years ago.
• Scat crank was installed, as well as a .280 cam, bored, new pistons, Z head, etc. nothing was spared. Transmission and rear-end were also totally rebuilt at that same time. After quite a few tours and lots of local driving- no breakdowns.
• It runs great and pulls hills better that any of my 4 other Model T’s.
NOW the PROBLEM-> The engine has a noise. Not a knock (not a hollow sound), but more of a rattle. When? When accelerating at speed in excess of 25mph or going up a hill.
• Over the years, 2 well known Model T mechanics have disassembled/reassembled and both had the same opinion “it’s not a knock- it’s detonation”.
• Recently, my friend John Z and I have checked shim clearances, end play on the crankshaft, camshaft, and generator. No endplay. I just installed a rebuilt generator. The noise is still there.
• A few days ago, John and I took the car for a ride after the above adjustments were made and the same noise is still there.
• John was driving and listening, and after a few miles on the way home, he came to a stop sign with a mild/slight grade at take-off. He took off and held the trans in low to approximately 25-27mph, which is unusual for him. Then we both looked at each other rather strangely, and we both grinned and said, “NO NOISE on this hill!”. After another 2 similar tests, there is no noise if running in low, but shift to high, it returns.
At this point we both came to the conclusion that the noise may be coming from the transmission and NOT the engine.
Have any of you experienced this problem? If so, how did you correct the problem?
