Help with 1926-27 Upholstery tuck?
Fozz71
First Name: Jim
Last Name: Chochole
MTFCA Number: 50481
Board Member Since: 2003
Post by Fozz71 » Mon Jul 15, 2019 7:46 pm
Hey guys,
I am about to start my '26 Upholstery for my Touring car, can someone snap a pic or two of your upholstery so I can see how it fastens and it tacked down without a seat cushion in place? I am confused how the cover tacks to the bottom wood and then wraps around the sides of the backrest.
Thanks very much,
Jim Chochole
MTFCA Number: 4838
MTFCI Number: 115
Re: Help with 1926-27 Upholstery tuck?
Post by DanTreace » Mon Jul 15, 2019 8:54 pm
The hip pads go in first. Then the backrest lays down, tack the upper first, pull taut over the backrest springs, and tack to the wood tack strip at the base.
front seat backrest install.jpg (58.22 KiB) Viewed 1034 times
Hip pad on far right, fitted first, then backrest, tucked under behind.
Fozz71
First Name: Jim
Last Name: Chochole
MTFCA Number: 50481
Post by Fozz71 » Mon Jul 15, 2019 10:09 pm
Yep, thanks Dan. I am comfortable with the top and bottom tacking, my main question is sides of the back cushion- how do those get tacked and fastened to the spring and still be tacked into the bottom? Just wondering how it looks.
Thanks,
Jim
Fozz71
First Name: Jim
Last Name: Chochole
MTFCA Number: 50481
Post by Fozz71 » Mon Jul 15, 2019 10:51 pm
See circled sides, since there isn't a tack strip on the sides, how does the cover get fastened down?
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Jul 16, 2019 10:30 am
Jim
The sides for the backrest upholstery are made extra wide, they just 'tuck' in and under the backrest spring, the mushy padding gives the fill against the hip pads, or you can add more fill if you wish. No tacks, if you wanted to, you could just pull it away, but in reality it stays put, as the whole backrest upholstery is under tension of being tacked at the upper tack strip and at the lower tack strip across the horizontal.
The backrest spring 'floats' from straps hung from the upper tack strip.
This is a rear seat backrest, similar to how the front seat in a touring is done. The rear has wood stays, the front seat only a metal stiffener and uses a water proof cardboard backing panel to insulate the body metal from the spring.
Fozz71
First Name: Jim
Last Name: Chochole
MTFCA Number: 50481
Post by Fozz71 » Tue Jul 16, 2019 2:24 pm
Thanks very much- that is a huge helper!
