Starting crank arm question
Topic author - Posts: 333
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
- MTFCA Number: 52438
- MTFCI Number: 22121
- Board Member Since: 2006
Is there supposed to be a small hole near the end of the starting crank arm for the spring to attach to? I can't seem to find one on mine, but it's been recently painted and I don't know if the hole was filled in with paint.
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
Re: Starting crank arm question
Yes they all have a hole 5 3/4" from the end on the right side in line with bottom of the hole, Bob
- First Name: Bill
Thanks, Bob, that's kinda what I thought but couldn't remember exactly where the hole was; your photos and measurements helped tremendously!
- MTFCA Number: 16175
- MTFCI Number: 14758
It's very common for that hole to be so filled with paint and/or crud that it's hard to find.
- First Name: Bill
Alright, now that I've finally located the hole is there a trick to getting that spring on??? It's brand new so it's pretty stiff.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
I had difficulty with adding the new spring and realized the end that is bent over is longer than required.
Grinding off half the length made it much easier to replace.
- Last Name: Golden
- Last Name: Golden
The above message was just a rest, but I over did it.
Nice to see this 2019 Forum actually working again!
