Neoprene axle seal T-2511-AS
Posted: Tue Jul 16, 2019 5:36 pm
When I tried to fit a new inner neoprene axle seal it seemed like the hole in the seal was not large enough to fit over the axle. I was able to push it about half way along the taper but it would have taken a large force to stretch it enough to slide onto the shaft.
My axle is 1.062" (which seems standard) and the hole in the seal is 0.78". Is this normal?
Regards
Colin
Regards
Colin
