Help Removing wheel bearing race.
Posted: Tue Jul 16, 2019 10:39 pm
by Modeltmike
I am changing wheels on one of my cars. I’m going to change the front wheel bearings. One of the outer races is worn thin and there is not enough “ledge” to get behind to knock it out. I am looking for ideas before I try my “untested” idea. Thanks!
Re: Help Removing wheel bearing race.
Posted: Tue Jul 16, 2019 10:42 pm
by Modeltmike
I added a photo. Thanks
Posted: Tue Jul 16, 2019 10:43 pm
by Walter Higgins
Carefully lay a MIG weld bead on the i.d. of the race, let it cool, and it will fall out when it shrinks.
Posted: Tue Jul 16, 2019 10:45 pm
by D Stroud
Mike, if the race is junk, run a weld bead around it or heat it cherry red in two or three places and let it cool. Then turn the hub over and it will probably fall out on it's own. Dave
Posted: Wed Jul 17, 2019 6:54 pm
by Doug Keppler
You could get on the edge of that with a sharp chisel, Ive never had a bearing race beat me. Come on Mike, you can do it!
Posted: Wed Jul 17, 2019 7:35 pm
by SurfCityGene
Any kind of a weld on that bearing race will let it fall out!. That's the only way to get them out of a blind hole like in the top cover of a gear box. Done it many many times. Amazing!
Posted: Wed Jul 17, 2019 9:54 pm
by Modeltmike
Thanks for the ideas!. I like it. A bigger hammer and/ or more voltage. Tim the tool man Taylor would be proud. I will let you know how it goes. Thanks!
Posted: Wed Jul 17, 2019 11:12 pm
by Walter Higgins
What is your "untested idea"?
Posted: Sat Jul 27, 2019 7:05 pm
by Modeltmike
Ground around on an old chisel. This allowed me to get over that little “hump” and get solid contact behind the outer bearing. Inner bearing was not an issue. Thanks
Posted: Sat Jul 27, 2019 9:56 pm
by DanTreace
Mike
Nice tool work.
Have done similar with a modified long masonry star drill.
Would like to find this tool, made for the job! Curved to bump out the inner or outer race.
IMG_8367 (500x409) (2).jpg (108.23 KiB) Viewed 5401 times
