Shift knob in transmission
Posted: Wed Jul 17, 2019 12:32 pm
by Jed
Amateurs that we are, we dropped the Ruckstel shift knob into the open transmission. Yes, we had removed the cover to look at what needed to be done besides changing the bands. We had already drained the oil. We made pusher and grabber rods out of coat hangers. We stuck a hand in as far as we could and put our finger up the drain hole. The knob is not metal so a magnet is out. So far, we cannot even prove it is in the transmission. We have made no contact with the knob. Where can it be hiding? Could the knob have gotten into the oil pan? We have even tried slowly turning the crank to see if that would make a difference or at least contact with the knob, Nope... All help and ideas welcome.
The knob diamiter(sic) is inch and a half (1-1/2")
The T sits on a concrete slab with a garage wall on one side and 20' of open concrete on the other three sides.
Re: Shift knob in transmission
Posted: Wed Jul 17, 2019 1:09 pm
by Scottio
First step is to stand back and say damn. Not really sure what your next step should be other than fish around with mechanical fingers. But I’ve got the first part down pat.
Posted: Wed Jul 17, 2019 1:29 pm
by babychadwick
Double check the undercarriage, pan arms etc. .
It may not have made it to the ground or black hole
Posted: Wed Jul 17, 2019 1:30 pm
by John Codman
I agree with Scottio, but would suggest a couple of shots of good Bourbon and a period of doing something else before trying the mechanical finger thing.
Posted: Wed Jul 17, 2019 2:11 pm
by Ruxstel24
Usually the shift knob has a steel insert for the threads ??
Maybe worth investment in a borescope...HF ?
I agree with Chad, look everywhere possible first. Might help to remove the hogsheads.
I don't think there's room to make the trip to the bottom of the abyss.
Posted: Wed Jul 17, 2019 2:19 pm
by Tiger Tim
I seem to remember having a hell of a time just getting bands in and out, are you sure something the size of a golf ball could fit in there?
Posted: Wed Jul 17, 2019 2:54 pm
Like others would check under the chassis, around the outside of the hogshead, against the frame rails, etc. Search the T anywhere but the opening of the hogshead to rule out other locations of that bouncing ball knob.
Then really check the floor, I like to lay down and sight along the flat surfaces, find things that way..
Then, maybe the knob did fall into the trans, would be unlikely for it to fall into the magnets on the flywheel, but if it did would be hard to reach, like a ball on a roulette wheel, between a pair of magnets perhaps.
Other places would be under the bands, as it could roll off the bands and fall below. Or on the rear of the hogshead, under the clutch spring, but that part of the pan is tapered towards the sump, so it would be in the sump then.
About the only suggestion I have is to drain the oil, fold a length wise shop towel in and hand crank it over, hoping the wad of towel will scoop the knob up along side the flywheel. :roll:
Posted: Wed Jul 17, 2019 3:25 pm
by HaroldRJr
I'm thinking that it just rolled behind something in the shop. If your shop is like most, there are a lot of things a shift knob could roll behind and out of sight. I find that as a last resort, it helps to find a lost item by using a bright flashlight so as to light up large, as well as very small shadowed areas, and it also helps to focus your vision so as to check each little area more completely, rather than just "scanning" a large area with less emphasis on the tiny little shadowed areas. Anyway,....try the flashlight idea, as the worst you can do is to accidentally locate something else that you didn't realize was "lost",......hope this helps,.....harold
Posted: Wed Jul 17, 2019 3:42 pm
by keen25
Try Some compressed air and a blow gun to try and hear it moving around. The cheap $7 cameras that use a pc usb port are nice. I would also look around the shop floor or other parts of the frame. Best of luck
Posted: Wed Jul 17, 2019 5:00 pm
by RustyFords
I would look on every possible ledge on the T first....places like inside the U shape of the frame rails, under the front seat, etc.
Posted: Wed Jul 17, 2019 6:01 pm
After getting over the shock, I'd wire a large nut as close in size to the knob and then see where it IS NOT
You may find there are only a limited number of places (if any) in the transmission that it will go into, when the hog's head is in place
Posted: Wed Jul 17, 2019 6:28 pm
Since the Ruckstell knob is screwed to the shift lever, how did it manage to come off in the first place?
Posted: Wed Jul 17, 2019 7:15 pm
by Jed
Jed's reply or replies,
'Original Smith', My partner still cannot remember what posessed him to unscrew it. I guess it the same demon that caused him to drop it. Actually, he was removing the wooden floor board.
'overall reply', our T sits outside under a canopy and a full tarp. The area around the T is all open concrete. I have been under it a dozen times working on removing rust from the frame, drive train, running boards, fenders, etc.. I cannot think of one part of our jewel that I not had my fingers or brush into. It was a month ago that the knob was dropped and my partner swears he saw it fall into the transmission. We have removed the Hogs Head to look it.
We will try the air. We will try the large nut. Are you sure the 'shop towel' will make it all the way around and not get hung up and cause more problems?
I wish our transmission looked as nice as the one in the pictures.
Posted: Wed Jul 17, 2019 7:28 pm
by SurfCityGene
You didn't say what size the knob was? That may make a difference where you look. I like the camera option..
Good Luck. IN THE MEAN TIME, PUT THE COVER BACK ON!!! Take the key out as well.
Posted: Wed Jul 17, 2019 8:27 pm
First, I'd respectfully suggest that a shop towel is not the way to go if the hog's head is installed. I do not believe that the knob will pass the pan at any dimension, and you may simply jamb things up if the engine is rotated the "wrong" way and the knob is indeed there.
If the nut routine shows that the knob may indeed be in there, yet is not visible, you may have to remove the hog's head. The knob should become visible and at that point, if you need a rag to "sweep" it up, then (with oil drained), a rag or rags can then be dragged safely into the cavity by the ring gear teeth. I'd never put a rag into a transmission and turn the engine over unless the hog's head is off
I'd remove the spark plugs and put the car in high gear, jack up a rear wheel and have someone turn the wheel over slowly one direction of the other as necessary to bring that sucker up. Annoying, but not a tragic deal.
In any event, have you learned NOT to do ANY unnecessary work with the transmission door off?
