What Transmission Is This Bracket For?
Last Name: House
MTFCA Number: 115
Post by George House » Fri Jul 19, 2019 11:29 am
...All I know is that it’s not Ruckstell. Anybody know? It matches the forward end collar of the T torque tube...
May your character not be a writing in the sand but an inscription upon the rock.
Last Name: House
MTFCA Number: 115
Re: What Transmission Is This Bracket For?
Post by George House » Sat Jul 20, 2019 7:07 am
**btt**
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sat Jul 20, 2019 1:14 pm
The early Hall-Scott shifter mount for the TT truck was similar - mounts to the 2 right side ball cap bolts, top & bottom - not the top 2.
Last Name: House
MTFCA Number: 115
Post by George House » Sat Jul 20, 2019 7:00 pm
Thanks Steve...now, does anybody have a need for it ??
Post by Allan » Sat Jul 20, 2019 8:31 pm
I worked on a T buckboard with a Ruckstel that had two of those brackets, one on each side of the ball housing. The standard Ruckstel shifter was mounted between them.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sun Jul 21, 2019 3:13 pm
Doesn't look like anything Ruckstell ever made to me! I don't even think the two holes line up with the ball cap.
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 21, 2019 3:21 pm
George, if it matches the ball cap holes, I’d be interested in it. I’m still working something up for my jumbo planatar. Tmorsher@icloud.com if you want to discuss.
Last Name: House
MTFCA Number: 115
Post by George House » Sun Jul 21, 2019 6:14 pm
Well, you think wrong Original..Now I’ll contact Tim...george
doodlebugt
First Name: Bruce
Last Name: Csorba
Post by doodlebugt » Mon Jul 22, 2019 7:53 am
Here is the complete set up.
It was operating the ruckstell in our 25. (Similar to what Allan saw)
It has LH and RH cast into each side and part Nos 2056 and 2057 stamped in.
Bruce Csorba
Melbourne, Australia
15 4-spring Rajo racer
17 C-cab van
25 "Dalgety" Tourer
Last Name: House
MTFCA Number: 115
Post by George House » Mon Jul 22, 2019 8:05 am
Most interesting Bruce ! You’ve enlightened all of us. Many thanks !!
Post by Allan » Mon Jul 22, 2019 8:17 pm
That's the one Bruce. At the time I was working on the buckboard, I was pondering whether the lever could be mounted to the left or right by switching it in the mounting brackets. I think it is possible, but wonder if there is any advantage.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Jul 22, 2019 10:40 pm
I believe that due to the TT having the battery box next to the running board, the shift rod going rearward goes straight back whereas on the passenger car equipped w/electric starting equipment with the factory battery holder, the shift lever goes to the passenger side to cross over the torque tube in order to miss the battery.
