Installing Manifolds
Topic author - Posts: 57
- First Name: William
- Last Name: Goodheart
- MTFCA Number: 30991
Is the manifold installation tool sold by Langs (#3066MTG) for $29.95 worth having? Does it make a difficult job easier? Can the job be done without the tool?
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Re: Installing Manifolds
The job can be done easily without a tool if you have a helper, or with some effort by yourself. A manifold clamp with one arm cut off makes a good tool.
- MTFCA Number: 16175
- MTFCI Number: 14758
I hate the idea of cutting up original parts, so I made these.
- MTFCA Number: 52564
I just turn the two outer clamps sideways and install the exhaust manifold first then the intake and two inner clamps, no cutting involved. Does the tool work, I am sure it does, is it needed, not really. There are work around's.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
I have coffee cans of both style clamps so cutting a couple off didn't hurt my feelings none but I do reverse of Mark's installation procedure - I install intake first to verify ring & gland seating then install exhaust as you can also verify seating looking down across the manifold - you can't see the intake if you mount the exhaust first.
- First Name: Jeff
- Last Name: Stevenson
- MTFCA Number: 50006
I got a couple of these from Erik B when we did my tranny. Boy did they help while I redid my Winfield linkage last week. Intake was on an off a dozen times until I got it right. In hindsight, I should have removed the exhaust manifold and done it last as you suggested though. Would have saved some grief for sure! Next time!RajoRacer wrote: ↑Sat Jul 20, 2019 3:07 pmI have coffee cans of both style clamps so cutting a couple off didn't hurt my feelings none but I do reverse of Mark's installation procedure - I install intake first to verify ring & gland seating then install exhaust as you can also verify seating looking down across the manifold - you can't see the intake if you mount the exhaust first.
Jeff
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
Thanks to everyone for the helpful suggestions. I got the answer I was hoping to get, I don't need to buy the tool to do the job. I can hold on to my $30.00 for something I really need. I hope to be installing both manifolds in a couple of weeks That is if I can finds enough time between Drs. appointments. I hope to get the engine back in my 1919 touring this summer.
