The TT project begins
70shovelhead
First Name: Preston
Last Name: Wells
Board Member Since: 2008
Post by 70shovelhead » Fri Jul 26, 2019 7:05 pm
Been about a year trying to get this truck. Finally got it bought and took deliver of most of the chassis and "wheel kits". Got front wheels with new felleos, tires, tubes and flaps. Just grabbed a pair of rings on ebay so should be good there. Have 4 rears and 4 rings to choose (that will come later) from and will need new rubber. As you can see the truck was disassembled, parts bagged and labled, new parts bought. What I'm looking for now will be a "reassembly book, diagram or whatever. Everything forward of the firewall I'm good with. The transmission is followed by a Warford aux. trans. and I'll get into those questions later. Keep the line open cause I'll probably have some questions along the way and will keep pictures posted of progress. First step will be to sandblast and paint the frame and front end component and suspension.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
70shovelhead
First Name: Preston
Last Name: Wells
Re: The TT project begins
Post by 70shovelhead » Fri Jul 26, 2019 7:06 pm
The engine, cab and sheet metal and radiator will be picked up in a few weeks.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Last Name: House
MTFCA Number: 115
Post by George House » Fri Jul 26, 2019 7:31 pm
Congratulations on the acquisition and welcome to the affliction. Consider powder coating the frame and front end - maybe even the axle housings. Both painting and powder coating require sandblasting. The latter treatment may even be cheaper and much longer lasting.
That cast iron Warford is both the best thing and most dangerous thing for a TT. Will require you master a ‘technique’ in shifting or you’ll have no service brakes - real scary.
“Fear is a Reaction...
Courage is a Decision”...Sir Winston Churchill
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Fri Jul 26, 2019 7:33 pm
Awesome, another TT is going to hit the road again. Looking forward to seeing your journey of progress!
70shovelhead
First Name: Preston
Last Name: Wells
Post by 70shovelhead » Wed Aug 07, 2019 5:27 pm
Well the TT frame made it to the sand blast/powder coat shop yesterday. In the mean time Im preping suspension parts for primer and paint. The spindles have to be replaced so I spent 4 hours and the blue wrench to get the rt steering arm off. Also dove into the genny only to find a bad brush plate. Still debating on fixing it or just replacing. Also got the front wheels. bolted together ready for a final sanding and paint. Then mount the front tires. Will tackle the rest next week....but first a trip to the mountains for a few days then more to come.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
PDGx
First Name: Paul
Last Name: Grohsmeyer
MTFCA Number: 27359
Post by PDGx » Thu Aug 08, 2019 10:31 am
Lookin good.
You need a bed for it ?
It was modeled after a wood TT bed design.
8’l x 3.5’w(flares to 4.5’) x 14”h (20” at top of flare)
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
Can’t, ain’t Possible
‘17 TT / Holmes Wrecker
‘22 Mack AC
70shovelhead
First Name: Preston
Last Name: Wells
Post by 70shovelhead » Wed Sep 11, 2019 8:52 am
PDGx thanks for the bed offer. Going to go with a conventional flat bed. So we have made some progress and getting closer to getting the chassis rolling. New ring gear, seals and gaskets installed in the rear end. Front end completely rebuilt and replaced the right spindle. New pawl and spring for the E brake. Looking for an affordable set of 6.00x20s. Then we can dig into the engine/trans.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Thu Sep 12, 2019 11:04 pm
Looking great!
Preston, is that a 12-24 H-P (code ;) ) sittin' close by to your TT? Cool. My brain said 12-24.
