and into gear. This makes cranking virtually impossible. Starting is only
accomplished by depressing the clutch pedal. What adjustments are needed to
prevent this ?
When cranking to start, it “slips” out of neutral . .
Topic author - Posts: 7
- Last Name: Markel
- * REQUIRED* Type and Year of Model Ts owned: 1909 Toring
- MTFCA Number: 10085
Re: When cranking to start, it “slips” out of neutral . .
Teeth on the quadrant and the pawl tooth on the handbrake are all rounded off from 95 years of ZZZZZIIIIICCCCKKKK! Pulling on hand brake and allowing pawl to bounce across and wear out every tooth there. Badbadbad technique.
You need a new one of these: https://www.modeltford.com/item/3448Q.aspx
And this: https://www.modeltford.com/item/3458.aspx , however, I choose to grind a new profile on this original part and save myself that disassembly...FWIW
NH Full Flow Float Valves
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
Hi, James. What Scott said. For temporary you might slip a piece of 1" pvc pipe a few inches long down over the handbrake handle so it will hit the dash and prevent the lever from going forward into high gear. Please don't ask how I know this.
- First Name: David
- Last Name: Menzies
- MTFCA Number: 27825
- Board Member Since: 2012
There are lots of funny photos of crankers being pinned against the garage wall, I don't have one right now.
- MTFCA Number: 28924
Right on. Push in the release just a little to avoid the RaaaaaaaaaaaK!
I guess some didn’t learn to do that way back when. I have 4 frames and on one the ratchet is almost smooth but just enough to maybe have held the brake lever.
- First Name: Andre
- Last Name: Valkenaers
- MTFCA Number: 23792
- MTFCI Number: 19330
Just for your all safety.
Do not try to repair the quadrand and pawl just replace it with the hard steel ones the part dealers offer.
Andre
Belgium
Andre
Belgium
