Babbitt Material
Posted: Tue Aug 06, 2019 6:58 pm
by keen25
Where is the best place to buy Babbitt material? Who has the formula that is the best grade or one that is the same composition as the Ford model T? Thank you. Erick
Re: Babbitt Material
Posted: Tue Aug 06, 2019 7:57 pm
by Erik Barrett
I buy government grade #2 from United Metals. They publish their formulae online and it is what Ford used for model T’s.
Posted: Tue Aug 06, 2019 8:15 pm
by Kerry
If your only doing 1 engine then buy the babbitt from the T vendors. I don't know about your area but down my way if you want babbitt from a metal merchant supplier you can only buy in bulk, which is fine if doing several engines.
Posted: Tue Aug 06, 2019 8:21 pm
by Kohnke Rebabbitting
Erik Barrett wrote: ↑Tue Aug 06, 2019 7:57 pm
Not the same as Fords, Erik.
Herm.
Posted: Tue Aug 06, 2019 9:15 pm
by Dan Hatch
Here a place that makes Ford babbitt.
http://stores.acrosales.com/fordbabbitt/
Dan
Posted: Wed Aug 07, 2019 8:04 am
by modernbeat
While there is debate about what is the "best" Babbitt, there are a number of similar materials to what Ford specified.
You can buy smaller quantities here:
https://www.kappalloy.com/babbitt-alloy ... urakapp-2/
https://www.kappalloy.com/kappatinningt ... -1-lb-jar/
Posted: Wed Aug 07, 2019 11:24 am
by Erik Barrett
Herm, please elaborate. I’d like to learn more.
Posted: Wed Aug 07, 2019 3:46 pm
Erik Barrett wrote: ↑Wed Aug 07, 2019 11:24 am
I will try to do it tonight, Mr. Erik, I am pouring in a 1903 Olds, today.
Herm.
Posted: Wed Aug 07, 2019 4:11 pm
by Dropacent
Here it is !
[attachment=0]
Posted: Wed Aug 07, 2019 5:24 pm
by Kerry
Posted: Wed Aug 07, 2019 9:47 pm
Just because babbitt has Ford in the babbitt, does not mean it came from the Ford Factory, it may be 86-7-7, but it didn't come from Ford.
The babbitt in the Ford Garages, that we got with Wilson tools, that was Ford Babbitt, all had Ford Imprinted in the bar, and written out, Just like the Model T, and A, signs.
We have had a lot of Babbitt that was Printed Ford in it, but was lead Babbitt. Henrys, Gyp parts.
Most all Bearing Manufacturers, used Grade No. 11, specified by car builders.
We use Grade No. 11, and also a lot of Grade No. 2.
We don't use much of 86-7-7, Ford formula, as it machines dirty.
Herm.
Posted: Wed Aug 07, 2019 10:28 pm
by John E. Guitar
Just in case anyone in Australia stumbles across this thread, I use Consolidated Alloys "Auto" white metal.
http://www.cagroup.com.au/wp-content/up ... s-2017.pdf
You can buy it direct from them or order it through a reseller like Blackwoods or Bunnings Trade.
Posted: Wed Aug 07, 2019 10:34 pm
by Dropacent
BUT IT SAYS “GENUINE “. Thought I’d go fishing with that pic and I caught a big one !
Posted: Thu Aug 08, 2019 1:19 am
by Erik Barrett
Herm, thanks for the input. I will stick with grade 2. My book on rebuilding model A’s claims that Ford went to a cheaper lead base babbit because they thought the more robust, larger crankshaft did not require the more expensive grade. Maybe that is why the Ford name is on some lower grade babbit ingots? Just a thought. Is your Oldsmobile project a curved dash one cylinder? Always an admirer of your work and formidable experience. The oldest thing I have done bearing work on is a 1904 B Ford.
Posted: Fri Aug 09, 2019 2:09 am
by BuddyTheRoadster
Herm, how do you chose when you use Grade No. 11 and when you use Grade No. 2 Babbitt?
Posted: Fri Aug 09, 2019 9:49 pm
Erik Barrett wrote: ↑Thu Aug 08, 2019 1:19 am
Grade 2 is fine, we use it some times. Buddy, it all depends on price, and availability.
Yes, that was in, I think early V-8's. The Early Ford V-8 Forum would know.
Yes, Ford tried Lead, a Copper Lead, it didn't work out, so they went to a Cadmium Sliver alloy.
The V-8 Ford Ron Bearings were never repoured, as they wear on out side, and in.
The olds is a Curved Dash, 1903. we have don a Shott " SP " A Yale, and I can't think of the other.
Herm.
