Lucky Find!
Dan B
Last Name: Blaydon
Lucky Find!
Post by Dan B » Sat Jan 19, 2019 8:39 pm
Today my Dad and I went to the Cabin Fever Expo in Lebanon, PA. It’s a model engineering show with all kinds of scale hit and miss, steam engines, etc. on display, most of them running. It’s the kind of show that anyone on this forum would certainly appreciate and enjoy.
They have a small flea market area with all kinds of odds and ends. While browsing, we came across a box lot with a couple Ford oil cans and half a dozen common Ford wrenches. Well we ended up coming home with it but didn’t really realize what we had until we cleaned up the one can and did a little reading (thanks Vintage Ford and ‘Oil Can Czar’!)
The can with the copper plating still present is a Noera Manufacturing Pat. 1908 with the bayonet style spout (Can #1 from the VF Sept/Oct 2013 article). The other, which was covered in gunk, is also a Noera Manufacturing Pat. 1908, with a threaded spout and the double Ford Script (Can #4 from VF Sept/Oct 2013 article). Both are in incredible, original condition as you can see.
What are the odds of finding BOTH in a cardboard box at a flea market? In any case, thought folks would enjoy seeing pictures of these early cans!
AdminJeff
Last Name: Stevenson
MTFCA Number: 50006
Re: Lucky Find!
Post by AdminJeff » Sat Jan 19, 2019 9:04 pm
Very cool. I filled the can in my ‘21 and oil went everywhere.... so I had it powder coated gloss black to match the car and now it looks great, especially empty!
Jeff
Assistant to the Grand Poobah MTFCA Site Admin
1921 Touring
wayne sheldon
Re: Lucky Find!
Post by wayne sheldon » Sun Jan 20, 2019 12:17 am
Very nice! All these years, I have never had an original Ford oil can.
MTFCA Number: 16175
MTFCI Number: 14758
Re: Lucky Find!
Post by Steve Jelf » Sun Jan 20, 2019 12:27 am
I saw one at Hershey priced at $60 and passed. Later I found another and when the guy said $2 I couldn't get the money out fast enough. My $2 can isn't bad, but yours have more copper left. They look great.
MTFCA Number: 121
MTFCI Number: 16310
Re: Lucky Find!
Post by Original Smith » Sun Jan 20, 2019 10:02 am
Both of your cans are nice, but the big one, even though the patent date says 1908 is not that early! The one below it with the Ford script in two places is the earlier of the two, and was used in the brass era.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Re: Lucky Find!
Post by Dallas Landers » Sun Jan 20, 2019 10:15 am
Steve, you are thrifty but mine was cheaper. Still has some plating on it and the holder that mounts under the hood. A friend gave it to me and said it belongs on my TT instead of sitting on his shelf.
Dan B
Last Name: Blaydon
Re: Lucky Find!
Post by Dan B » Sun Jan 20, 2019 11:27 am
Larry,
Why do you think the nicer one with the large Ford script is later? It has the bayonette style cap referenced in the VF article and dozens of posts on the old Forum discuss this can as being pre-1915. Here’s one for example: http://www.mtfca.com/discus/messages/17 ... 1297907656
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Re: Lucky Find!
Post by david_dewey » Sun Jan 20, 2019 1:29 pm
the Caswell brush plating kit will re-copper oil cans beautifully. The one I did is put away or I'd take a picture of it. You do have to de-grease (de-oil?) the can to make it work, and when I did it, the plating looked spotty, but a quick lick of liquid polish evened it out.
T'ake care,
David Dewey
MTFCA Number: 121
MTFCI Number: 16310
Re: Lucky Find!
Post by Original Smith » Sun Jan 20, 2019 9:24 pm
The reason I know it is earlier, is because it is. Look in an early Ford parts book, pre '15. and you will see for yourself!
REHelgeson
Last Name: Helgeson
MTFCA Number: 31827
MTFCI Number: 25052
Re: Lucky Find!
Post by REHelgeson » Tue Jan 22, 2019 1:19 pm
Larry, what years did Ford use the oil cans with the bayonet top? I would agree the one with Ford script on two sides is the earlier of the two.
Dan B
Last Name: Blaydon
Re: Lucky Find!
Post by Dan B » Tue Jan 29, 2019 12:55 pm
The MTFCI judging guidelines for 1913 state that the Maple City and Noera branded cans used the bayonette style cap.
George Andreasen
Last Name: Andreasen
Re: Lucky Find!
Post by George Andreasen » Tue Jan 29, 2019 12:58 pm
Jeff
Jeff, this is where gas tank sealer does double duty. Clean out the inside with lacquer thinner, allow to dry and slosh with a tiny bit of sealer. Let that dry and fill. No leaks!
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Lucky Find!
Post by R.V.Anderson » Tue Jan 29, 2019 1:43 pm
I believe the Judging Guidelines now state that the bayonet style can was used pretty much throughout the T era; the threaded spouts are Model A. The double script can was apparently the first style used, around 1912-13 or so.
