Re: Himico Cylinder Head
Posted: Sat Aug 10, 2019 1:30 pm
by Dropacent
Just ping from my poor memory, but I believe they had Himico in raised letters. If you search long enough you should be able to find a picture. Model T haven had a very complete engine not too long ago. Good luck, fascinating motors !
Posted: Sat Aug 10, 2019 1:40 pm
by Dropacent
Maybe I’m remembering the manifolds with raised HIMICO on them . Sorry, not much help
Posted: Sat Aug 10, 2019 3:33 pm
by Dropacent
Tim, he had a really nice complete one maybe 6-8 years ago, also. I’m still seeing a himico head in my brain. That was a fantastic engine you just got, great buy! I was very tempted.
Posted: Sat Aug 10, 2019 5:04 pm
by Dropacent
I’d love some detailed pics of your new motor. I think others would, too.
Posted: Sat Aug 10, 2019 5:09 pm
by Mark Nunn
Tim, I thought I saw your RPU on Craigslist recently. Was I mistaken or did you change your mind?
Posted: Sat Aug 10, 2019 7:10 pm
by Henry K. Lee
Tim,
Thank You for sharing! Pretty Awesome!
All the Best,
Posted: Sun Aug 11, 2019 12:17 am
by Jim, Sr.
Tim,
It appears that you do have the HIMICO high velocity cylinder head on your engine. In the original 8 page sales literature it shows the head, and it has most of the little knobs on the top of the head like yours does. I do not remember ever seeing them on any other accessory head for a Model T Ford. Here are some photos from the sales literature.
I hope that you did not pay too much for the Himico. It only cost $184 when it was new.
Posted: Sun Aug 11, 2019 12:44 am
by Dropacent
- 665CCFCC-E231-435B-9111-627E2A36A98F.jpeg (94.59 KiB) Viewed 7570 times
- A19FF3AE-8196-41C9-B5D2-8A6B5A494382.jpeg (57.46 KiB) Viewed 7570 times
Posted: Sun Aug 11, 2019 12:46 am
by Dropacent
Thanks for the pics and all the other info. Looks like you could buy a kit or a complete remanufactured T engine with all their stuff on it. This is the nicest complete one I’ve ever seen, Tim
Posted: Sun Aug 11, 2019 8:59 pm
by Dropacent
- 7D42E2D6-AFCC-416D-9E6E-52FBDD577BA3.jpeg (9.48 KiB) Viewed 7440 times
Although advertising cuts are notoriously misleading, this one shows some writing on the top of the head, I presume raised letters of HIMICO. It doesn’t make sense they would be so conscious of branding on all their other parts and then not on the head. I guess until one shows itself we will not know for sure. I agree, those raised bumps appear on the cut also. I’m guessing they were core wires or actual casting that was left in place for strength, similar to shoring posts in a coal mine. I’ve seen those in some other aftermarket heads, such as Ricardo . These were made on much smaller scale than ford ever did.
I’m still trying to find a couple simple measurements on a weaver crane, still no luck. Half the fun is the search! When I find a HIMICO branded head, I’ll holler.
Posted: Sun Aug 11, 2019 9:32 pm
by Tim Moore
The HIMICO motor I had was complete except for the lost shift plate. The head was marked AC.
Posted: Mon Aug 12, 2019 6:01 pm
by Brian Cress
Here is a shot of our Himco:
Posted: Sat Nov 09, 2019 7:47 pm
Doesn't look like the combustion chamber of that head would be any better than a Ricardo, or Giant Power.
Posted: Sat Nov 09, 2019 11:02 pm
by Jim, Sr.
I found another piece of HIMICO literature recently that is probably later than the other photos that I posted in August when you bought the HIMICO from Model T Haven. Because this piece has the wide pedals like a stock 1926-27 Model T engine, rather than the narrow paddles like the earlier engines, I think that probably dates it.
Posted: Sun Nov 10, 2019 7:37 am
by Joe Bell
I have one of those heads on my fordor and have ran it for years, works great, I have an extra one that I may part with, no cracks! Thanks Joe
Posted: Sun Nov 10, 2019 3:52 pm
by Jim, Sr.
Tim,
I wonder if the complete engine unit that you have is the Heavy Duty HIMICO like the one in the later literature that I posted?
The Heavy Duty type as shown should have 2 inch journals for the connecting rods and main bearings and a gear driven oil pump. It also does not have magnets on the flywheel or a field coil, so it requires a distributor or magneto.
