How many cups of grease does it take...
Topic author - Posts: 6496
- MTFCA Number: 16175
- MTFCI Number: 14758
...to fill the space around the U-joint? Curious, I didn't put in any grease when I assembled the thing, just to see how many cups it would take.
The answer is 23, at least in this case. After the car has run a few miles the grease may be spread around to make more space.
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Re: How many cups of grease does it take...
The best idea I've seen for these type grease cups is to install a modern Zerk fitting inside the cup. It sure does make greasing the T a simple task. It's important to grease that U joint often..
1912 Torpedo Roadster
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
Loading 23 cups of grease must have felt like groundhog day!
- First Name: Paul
- Last Name: Aranyos
- MTFCA Number: 50118
I love that experiment. I went through the same process 2 weeks ago, the following week I added a zerk.
A man has got to know his limitations!
Days. Arthur Itis suggested that it would be done best only five at a time.
- MTFCA Number: 121
- MTFCI Number: 16310
I'm happy you shared that. It's much easier to pack the cavity before you slide the u-joint into the engine. Then, all you need is to fill the grease cup a few times. If you install a zerk, then how are you going to keep the grease cup from coming off? It's better to not use a zerk.
You can buy them already made too, in steel or brass, for U-joint, steering, rear axle....
- MTFCA Number: 52564
"If you install a zerk, then how are you going to keep the grease cup from coming off? It's better to not use a zerk." Most of my grease cups for that size are not spring loaded if you are talking about the cap. If the cap unscrews from the base, you have more problems to deal with then just a lost cap. And even if you lost the cap it would be no big deal, no different then just installing a Zerk without the cup, both are pipe thread. I install mine dry and fill after, enough to deal with without the mess of grease everywhere. I find about 1/2+ tube of grease fills it from dry, but I am not going to go out a measure how many caps full that is!
Simple matter to unscrew the cup install a Zerk fill the housing then reinstall the cup for refilling later if you so wish.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 121
As the regulars on this forum know, I use original parts. The cap has a three or four sided stud which is welded to the cap. There is a spring affair that fits into the base, and when the two are engaged, it prevents the cap from loosening. Of course, if you have a zerk down there, it can't work.
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
I used one with a zerk when I assembled my drivetrain for the first time. It took 3/4 of a tube a grease to fill it from empty.
1924 Touring
- First Name: Kenneth
- Last Name: DeLong
Grease is cheap,but that much seem's if only to me excessive? Bud.
- MTFCA Number: 4838
- MTFCI Number: 115
Bud
Can’t have too much grease in the u-joint ball, Ford used the largest dope cup there. Takes about a full cup of grease to pack.
Have always packed it full on install of the engine, filling the joint and space in the torque tube ball, allows for the square end of the u-joint to stand up and not wobble in slack as you couple. Keep that u-joint packed each 500 miles.
- MTFCA Number: 121
A cup of grease is a lot of grease, but 23? Give me a break!
No, no, no. Not eight ounce measuring cups. We're not baking a cake here. This is about Model T GREASE cups.
And yes, I really did fill it and screw it on 23 times before it filled the cavity enough for grease to start oozing out around the cap. (See the first picture I posted above.) I assure you I'm not running for office, so I'm not lying.
- MTFCA Number: 30701
- MTFCI Number: 24033
Like Dan said...if you have the engine out or rear end out just make sure and the ball full. And yep it does make it very easy to keep the universal in place for an easy coupling. Just did that last week. Very quick and easy hookup. Then every 500 miles I give the Zerk fitting cup 20-25 pumps and its good to go. Plus 4-6 on the driveshaft bushing. Never had any trouble with the caps staying on the cups either!
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Filling the ball full of grease and continually adding more grease is like taking a whole bottle of aspirin. More is not better...
- MTFCA Number: 14972
- MTFCI Number: 15411
Quite a fitting analogy there, Adam !
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
How is having the ball full then adding some after it squeezes out under normal operation a bad thing? I would think having it mostly full would be an advantage for a healthy u-joint, and for preventing engine oil from going down the torque tube and into the diff. Me confused.
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
- First Name: Adam
- MTFCI Number: 1
Some grease squeezes forward into the transmission and engine. Modern grease does not mix readily with engine oil. Because the oil system is not pressurized, the grease has the ability to foul oil grooves and oil holes in the engine and transmission preventing proper lubrication. Grease also EASILY will plug up oil lines, even the accessory ones. It’s really important to keep any traces of grease out of non-pressurized engines.
- MTFCA Number: 121
Too bad that Steve didn't mention grease cups in the first place!
Huh?
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
If it's any small consideration, I got it right away Steve. I imagine some of us have been dealing with grease cups for all sorts of ancient machines for quite awhile. Me since I was a boy and never lost one yet but I am only 55.
Shoot, 5 cups at a time is a stretch!
I've lipped off about this before but I just took the entire, clean and correct cup assembly off the empty U-joint cover on the 18 and held the grease gun against the hole for the cup and started pumping. You prob'ly remember this, it took me a few tries to get it done but it was full. And a few more (grease) cups worth. Ouch. Then I sat down again and refreshed my self with a cold drink.
- First Name: Bill
- Last Name: Hoffer
OK. I will ask the question. Adam replied that some grease squeezes forward into the transmission and engine and may plug oil lines and grooves. I packed my u-joint with the fiberous yellow truck wheel bearing grease in hopes that it would stay put and not run out like regular grease. I also considered using the red grease for heavy equipment that stays put. Do these types of greases pose more of a danger of plugging the oil lines? Am I asking for trouble? What is the best type of grease to use in this location?
Fire at will, gentlemen, Bill
- Last Name: DeLong
I think most old time grease/dope cups often used what was called [soft oil].I have doubts about filling the engine with grease and if said grease is not soft or a semi fluid,how will it get into the inner parts of the U joint? Grease and oil are cheap but is there a need to under coat your car and leave a trail??Bud.
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
What kind of grease is recommanded?
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Don
- Last Name: Allen
Yo tambien.
It never even crossed my mind that this might be referencing baking (Imperial) measurements.
1924 Touring
- Last Name: Govoni
- MTFCA Number: 32331
Great info here. I always like reading what you write Mr. Jelf. I learn something every time. This was a good experiment. I bet there are many who just think that a few turns is ok on the cup.
- First Name: Duane
- Last Name: Cooley
Sorry Steve, drifting. Off the deep end but goll (Gol Ducat) I laughed! Intended or no, you guys made my good day great! Again!
Don, doggone it, you were speaking the Queen's Spanish and all I heard was French! I saw "Combien du temps" (combien du tom) in my head "How much time?" Hah! still relevant!
I had to look "Yo tambien" up! Me too.
You have a twisted sense of humor that suits and yet out performs my own! IMPERIAL MEASUREMENTS... Still laughing inside!
All I hear in my head NOW is my brain feeding me an English accent voice-over of the whole darned thing...
Nyes, we see that the hole bloody mess has to do with how many copps we ectually put into that bloody swivel-joint mmm?......
- First Name: Don
- Last Name: Allen
Duane....
I was raised in a farming community just north of Brownsville, TX and Spanish was practically my first language.
1924 Touring
...Spanish was practically my first language.
Here we go again, with a comment reminding me of something else. My late compañero de trabjo Carlos Sotelo was from Ojinaga, Chihuahua. I once asked him, "Why Kansas?" He said that for the first two years after he came to the US he lived in Texas, and realized he wasn't learning English. So he moved to where he would have to.
- First Name: Duane
- Last Name: Cooley
I got it pretty close Steve. A traveling buddy I thought.
Up here we know a little Norwegian, a bishen German and I obviously gravitate to French. Mostly swear words.
Interesting!
Interesting!
- First Name: Don
- Last Name: Allen
I've been having a lot of work done on my property lately and in this area, most of the laborers who are employed by contractors are hispanic.
With the severe heat the way it is around here in August, I've taken cold drinks out to the workmen and almost always take some time to chat with them (in Spanish) while they cool down. My kids are awestruck by my ability to not only converse with these guys, but to do so seemingly without an accent.
I think their amazement is due, in part, to the fact that I never speak Spanish at any other time.
I was thinking about it the other day. My dad farmed and raised cattle and so did his father. They dabbled in other things, but they were farmers above all else. As far back as we've been able to research, all the Allen men have farmed and raised cattle. This probably stretches back thousands of years. I broke the chain and now live near a city and wear a lab coat at work. My dad sold everything farm related and moved away from south Texas before my kids were born so they've never experienced something that their ancestors did since practically the beginning of time.
Talk about something that will stop and make you think for a minute.
Sorry about the thread drift Steve. I'll go squirt some more grease into that u-joint zerk this afternoon to get things back on track.
1924 Touring
- First Name: Arthur
- Last Name: Babitz
- * REQUIRED* Type and Year of Model Ts owned: 1927ish Roadster Pickup
I can verify Adam's comment about some of the grease working its way into the transmission. I pumped away at my zerk fitting, never seeing any grease come out of the U-joint cover. Next time I opened the transmission cover plate I found what I first thought was a dead mouse in the screen. It was a big glob of grease partially dissolved by the engine oil into a very mouse-like shape. It even had a tail. Should have taken a picture, but my hands weren't very clean.
It never occurred to me to check the oil lines, but I will do that now.
