What Puller Do I Need?
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Board Member Since: 2011
Post by Bill Everett » Wed Aug 14, 2019 7:03 pm
What modern puller will work to remove this hub?
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Re: What Puller Do I Need?
Post by Bill Everett » Wed Aug 14, 2019 7:05 pm
I meant brake drum, not hub.
Post by Allan » Wed Aug 14, 2019 7:14 pm
Bill, I'd be inclined to support the drum in a press and use the press to push the hub out. You will need a heavy tubular support for the drum. We keep a selection of starter/ generator housings for this purpose. Heat and rust penetrant may help.
Hope this helps.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Aug 14, 2019 7:22 pm
You probably will need to pull the hub first.
Then push out the wheel studs and remove the drum.
This puller will work...
https://www.amazon.com/OTC-6574-Univers ... 0359662961
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Aug 14, 2019 8:47 pm
Here's an original Ford w.w. hub puller.
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Post by Bill Everett » Wed Aug 14, 2019 8:53 pm
Steve, I'd truly love to find one of those for sale, or rent!
Post by Scott_Conger » Wed Aug 14, 2019 9:39 pm
Bill, I am posting this to spur your imagination...https://www.homedepot.com/p/URREA-Beari ... /202797899
If you have a pal with a lathe, you can turn up a split collar which will "grab" the hub and provide ample purchase area for a heavy puller to grab. Just be sure to remove the axle nut and turn it around and reinstall to keep from deforming axle threads.
Full Flow Float Valves - deliver fuel like Henry intended!
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Wed Aug 14, 2019 9:59 pm
I purchased this one from Harbor Freight for less than $10 and modified the ears and It worked great. The hub came off without out any heat.
If you can't pull It cold and have to heat It, pour a 5 gallon bucket of cold water on it after you get It red hot, be careful of the steam It will generate, It will shock the bond and it should come right off. And do as Scott said about the nut.
tdumas
First Name: Ted
Last Name: Dumas
MTFCI Number: 20999
Post by tdumas » Wed Aug 14, 2019 10:05 pm
Your local auto supply May loan you one for free. Our O’Reillys does that.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Aug 14, 2019 10:11 pm
With lugs like that I use a dog bone puller.
Post by Norman Kling » Thu Aug 15, 2019 1:01 am
use one of the pullers shown above to remove the hub. Then press out the lugs and the drum should come right off. When you install the new drum or re-install the existing drum, press in NEW lugs.
Post by Allan » Thu Aug 15, 2019 8:16 am
Bill, take no notice of me!!!!! I read that you were looking to remove the hub from the drum. Even then, I got it wrong. The studs are pressed out first and then the drum comes off.
Sorry.
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Post by Bill Everett » Thu Aug 15, 2019 12:56 pm
Clarification...
What puller do I need to pull the entire hub and drum off the axle?
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Thu Aug 15, 2019 1:01 pm
Any or all of the above shown will do the job - then the drum can be removed.
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Post by Bill Everett » Thu Aug 15, 2019 1:40 pm
Bill Crosby...
Do you remember the p/n of that puller at Harbor Freight?
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Thu Aug 15, 2019 2:31 pm
Bill Everett, I just looked at the puller and there are no markings on It. I purchased It from HF many years ago just for this purpose because I could not find my old ford hub puller. It did a good job at a cheep price.
Bill Everett
First Name: Bill
Last Name: Everett
MTFCA Number: 93
Post by Bill Everett » Thu Aug 15, 2019 2:32 pm
Thank you, Bill.
Billdizer,Spencer In
First Name: Bill
Last Name: Dizer
MTFCA Number: 28610
Board Member Since: 2014
Post by Billdizer,Spencer In » Thu Aug 15, 2019 7:10 pm
The harbor freight puller has been a pitman arm puller, before being modified. It is normally used to pull the steering pitman arm off the tapered splined shaft of a modern steering box. It looks like the opening between the jaws has been widened to fit over the slot in the hub.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Aug 15, 2019 7:50 pm
Yes, pitman arm puller. Most big auto parts chains have these heavier cast version.
China made but simple grinding of the lugs more wider to fit around the hub collar on wire wheel hubs lets them work.
Here’s mine:
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Mon Aug 19, 2019 2:52 pm
Dan, I stopped by Harbor Freight today and bought one of those pullers.
The Part Number is 63684 and it cost $14.95 today without any coupons.
The opening is listed as 1 5/16 and needs to be 1 3/4 inch for the rear hub.
By careful calculations, and cutting both sides, I have exactly 1 3/4 inch now.
The frame is very hard and it required a Harbor Freight electric cut-off tool to make clean cuts.
The tool works fine, thanks for the tip!
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Mon Aug 19, 2019 2:55 pm
Bill, that original Ford puller has a 5-Z-1172 number on it, but it is hard to see.
TheMoneyPit
Last Name: Wetherbee
Post by TheMoneyPit » Wed Aug 21, 2019 12:45 pm
GEE-WIZ JIM, how did you know that so quickly? (Personal joke, please ignore me)
There is no such thing as a “free” lunch... :D
